武器-装备 [热兵器] Unity次时代写实步枪AK47
1727
3D资源
3D资源分类: 引擎文件
资源题材: 现实
美术风格: 写实
3D资源格式: U3D-Unity
贴图规格与格式: 其他
软件版本要求: 未知或无明确软件版本限制
价格:45元素币(或4余额) 百度网盘 销售总额:585元素币 购买人数:13
尊敬的游客 ,本内容需要支付 45元素币十分之一的[余额] 来购买.
Triple A quality model and textures of the legendary AKM free to use for your FPS Unity project! If you like the quality of this weapon and you are in need for more check out the “Ultimate FPS Weapons Pack”which got you covered with over 22 triple A quality modern weapons for your projects.
What\'s in it?
Brought to you by Senior 3D Artist Tim “chamferzone.com” Bergholz this free AKM is ready for you to make use of in any Unity project.
The intended use for these models and its textures are first person shooters. Polycount is equal to current generation games.
High resolution textures exported out of Substance Painter. Materials meshes and texture names follow an easy to understand naming convention. Every element per weapon which requires animation has been detached and given the proper name. Each weapon material has the same name as the textures for it. You can downscale the textures from 4K to 2K or 1K depending on your needs but you\'ll get the highest resolution to decide for yourself.
Important note: Rig animations arms or sounds are not included! Weapon models and textures only.
Technical Details
Texture Size: 4096x4096
Physically-Based Rendering: Yes
Vertex Count AKM: 9568
LODs: None
Number of PBR Textures: 4 (Base Color Metalness Roughness Normal Ambient Occlusion)
Intended Platform: Desktop
Naming Conventions:
WPN_ = Weapon Mesh
WPNM_ = Weapon Material
WPNT_ = Weapon Texture
Contact:
In case of questions the best way to get in touch is to write a message through the official ChamferZone Facebook page. I\'ll get back to you as soon as I can.
https://www.facebook.com/ChamferZone
参与人数 2 元素币 +5 活跃度 +26
静脉 实名
2099 小时
短杖 水晶剑 紫色药水 赤色药水 翡翠剑 【绝】珍珠戒指 【绝】黄金项链 裁决 【绝】千人纪念徽章 学徒法袍 元素铜币 元素银币 元素金币 长枪 铁剑 火元素 长剑
