MAYA体积云制作软件Elementacular 1.5.1.0 for Maya 2017 and Maya 2018
效率神奇工具 219 1
发布于 2023-12-6 17:53:01
软件类型: 三维·建模 渲染 插件
版本信息: V1.5.1.0
系统要求: -
官网地址: https://elementacular.com/
价格:25元素币(或2余额) 百度网盘 销售总额:125元素币 购买人数:5
尊敬的游客 ,本内容需要支付 25元素币十分之一的[余额] 来购买.
Maya是Autodesk的三维角色动画软件,Elementacular是交互式云层建模渲染的插件,支持新型渲染,包括Arnold和RenderMan。
Elementacular允许用户使用Maya的网格操作界面设计云层的形状,同时在Viewport渲染器中实时展现美丽的体积云,可谓交互性与高质量兼备。
“导出至OpenVDB“使云层能无缝融入对整个场景的渲染——这意味着不需要后期制作和合成就能将Elemtacular的云层融入最终图像。
Maya is Autodesk’s 3D character animation software, and Elementacular is a plug-in for interactive cloud modeling rendering that supports new renderings including Arnold and RenderMan.
Elementacular allows users to design the cloud’s shape using the Maya’s grid interface, while displaying beautiful volumetric clouds in real time in the Viewport renderer, both interactivity and high quality.
“Export to OpenVDB” seamlessly integrates clouds into the rendering of the entire scene – which means incorporating Elemtacular clouds into the final image without the need for post-production and composition.
Get new Elementacular v1.5.1.0 Maya: plug-in for 2017-2018
Forget the long simulation and rendering times normally associated with volumetric 3D cloud construction.
The Elementacular MAYA plugin is simply a material applied to your geometry –
with lightning fast user-controlled fractal generation enabled by powerful GPU acceleration.
Quickly tweak your production quality results without having to re-parameterize.
You maintain full control over the cloud shape through direct manipulation of the underlying geometry –
even after it is converted into a cloud!
And if you want to change the look of your cloud – maybe turn it into a fireball or a special effect –
go ahead and adjust the geometry, lighting or fractal.
All in real-time!
FEATURES
Real-time production quality volume construction in Autodesk Maya.
The resulting volume automatically reflects the underlying geometry.
Physically based multi-scattering of light.
User-controlled volume characteristics.
User-controlled volume emission.
User-controlled reflectance.
Multiple light sources.
Full 32-bit HDR pipeline.
Export to OpenVDB.
512119961  发表于 2023-10-17 10:58:33
装了这个插件后maya闪退,这是什么情况?
