Ivy.Pro - ZBrush Plugin -植被生成插件
效率神奇工具 282 4
发布于 2023-2-11 00:36:44
价格:80元素币(或8余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 80元素币十分之一的[余额] 来购买.
此资源为Standard Use License版本
ivy.pro:
  • Ivy.Pro is a Plugin for ZBrush  that generates Ivy or other climbing plants on top of a polygon mesh.
  • There are many variables to play with but it might be hard to understand what each of the sliders do to control the plant growth, leaves orientation, forces etc… The intention was to make it easy to use without paying too much attention to the settings panel. Loading presets and maybe tweaking a couple of things, like the amount of branches or the overall scale, should be enough to get good results.
  • If you don′t get too intimidated by the settings panel you can create your own species and model your own custom leaves or flowers.
  • You can also export just the data relative to transformations (rotation, scale and position) in case you want to use instances in other 3D software or Game Engines that supports it. You will have to write your own importer...
  • I will add a importer for Blender in the future and release it together with a Blender Add-0n.
  • In Blender the leaves are simply instantiated from collections while the ZBrush version doesn’t use instances. A new SubTool is added  for every leaf type but it’s just plain geometry so meshes can get quite heavy.
  • In the ZBrush version you can generate a zsphere branching structure with no leaves associated with it.
Installation:
  • Plugins in ZBrush don't need to be permanently installed in order to use them. Simply unzip IvyPro.zip to your preferred folder and run the plugin from that location.
  • Most likely ZBrush will be the app associated with the ZSC file extension so loading the plugin should be as simple as clicking on the ZSC file. ZBrush will launch  with the plugin loaded in the Plugin subpalette and ready to use for the session. You can also load scripts directly from the ZScript Sub Palette.
  • To install the plugin, so it's loaded every time ZBrush launches, just move the IvyPro.zsc file and the IvyData folder to "Your Installation Folder" \ ZBrush 2019 \ ZStartup \ ZPlugs64 \ .
  • Ivy.pro needs Microsoft VC++ redistributables. Chances are they are already installed in your PC but, if they are not, just unzip  and run vc_redist.x64 to install the packages.
  • This plugin works on a mac with Catalina or newer OS. So it might not work for you.
  • Release Notes
  • The plugin is now compatible with older versions of ZBrush.
Removed a call for Preferences/Export/tri
Ivy.Pro 是 ZBrush 的插件,可在多边形网格上生成常春藤或其他攀缘植物。
有许多变量可供使用,但可能很难理解每个滑块在控制植物生长、叶子方向、力等方面的作用……其目的是使其易于使用,而无需过多关注设置面板. 加载预设并可能调整一些东西,例如分支数量或整体规模,应该足以获得良好的结果。
如果您没有被设置面板吓到,您可以创建自己的物种并为自己的自定义叶子或花朵建模。
如果您想在其他支持它的 3D 软件或游戏引擎中使用实例,您也可以只导出与变换(旋转、缩放和位置)相关的数据。您将不得不编写自己的导入程序...
以后我会为 Blender 添加一个导入器,并与 Blender Add-0n 一起发布。
在 Blender 中,叶子只是从集合中实例化,而 ZBrush 版本不使用实例。为每种叶子类型添加了一个新的子工具,但它只是简单的几何图形,因此网格可能会变得很重。
在 ZBrush 版本中,您可以生成一个没有叶子关联的 zsphere 分支结构。
安装:
ZBrush 中的插件无需永久安装即可使用。只需将 IvyPro.zip 解压缩到您喜欢的文件夹并从该位置运行插件。
ZBrush 很可能是与 ZSC 文件扩展名关联的应用程序,因此加载插件应该像单击 ZSC 文件一样简单。ZBrush 将使用插件子面板中加载的插件启动并准备好用于会话。您也可以直接从 ZScript Sub Palette 加载脚本。
要安装插件,每次 ZBrush 启动时都会加载它,只需将 IvyPro.zsc 文件和 IvyData 文件夹移动到“您的安装文件夹”\ZBrush 2019\ZStartup\ZPlugs64\。
Ivy.pro 需要 Microsoft VC++ 可再发行组件。它们可能已经安装在您的 PC 中,但如果没有,只需解压缩并运行 vc_redist.x64 即可安装这些软件包。
此插件适用于装有 Catalina 或更新操作系统的 mac。所以它可能不适合你。
发行说明
该插件现在与旧版本的 ZBrush 兼容。
删除了对 Preferences/Export/tri 的调用
参与人数 4元素币 +51 活跃度 +33 展开 理由
大西几 + 18 + 7 资源甚好,发帖艰辛,且阅且珍惜。
lhcppy + 8 + 8 给你一个666
liudongdon... + 20 + 9 带你赚币带你飞,元素里面有正妹。
xiye + 5 + 9 从业不识微元素,做遍项目不算数。
许多人想登上月球,而我却想多看看树。
avalonmk  发表于 2022-5-5 10:50:02
感谢楼主分享
随浪逐波  发表于 2022-5-5 10:51:36
壮士~等等我~  发表于 2022-5-5 11:25:30
秀儿
