RealFlow C4D R25流体模拟插件 V3.3.5.0057 For Cinema 4D R21-R25 Win破解版...
228 2
发布于 2023-11-19 21:02:30
RealFlow C4D R25流体模拟插件 NextLimit RealFlow V3.3.5.0057 For Cinema 4D R21-R25 Win破解版 image.png image.png 可以在Cinema 4D里面模拟RealFlow流体效果,仅支持Win版本C4D R21/R22/R23/R24/R25RealFlow | Cinema 4D gives you the best in fluid simulation, directly inside Cinema 4D. Now you can achieve high-end simulations with an even easier workflow.Look closer
  • 模拟高速微距拍摄时常见的流体效果。
  • Simulate fluid effect typically seen at Hi-speed macro photography.
Mesher meets Cinema 4D fields
  • 利用域来定义要网格化的区域。
  • Take advantage of Fields to define regions to be meshed.
  • 节省调整网格的时间。
  • Save time tuning meshes.
Cinema 4D oriented workflow
  • 更灵活地控制C4D样条线上的力和粒子发射器等
  • More flexibility to define forces and particle emissions along Cinema 4D splines.
Put all together
  • 只在一个文件中拼接模拟结果,粒子和网格。
  • Stitch your simulation results, particles and meshes, in just one Alembic file.
安装步骤:
  • 拷贝NextLimit文件夹到C4D安装目录的plugins即可
  • 如果提示没有激活,点击选择I have a node-locked lic,然后Next,选择Maxon Cinema 4D R25\plugins\NextLimit\LicenseActivator文件夹里面的nl_license_activator.exe,然后重启C4D即可
签名被屏蔽
wys88323  发表于 2023-10-13 15:12:05
实太炎凉  发表于 2025-5-20 14:09:50
