UE虚幻资源 [工具/功能] 虚幻4自定义动态十字准心包 UE4 Custom Dynamic Crosshair Pack
180
2
引擎插件类型
软件版本要求: 4.15 - 4.25
引擎插件类型: 材质|Shader
价格:50 元素币 百度网盘 收益:50元素币 销量:1
尊敬的游客 ,本内容需要支付后可见.
提醒使用【余额支付】需要: ¥5 余额
image.png 商城链接:https://www.unrealengine.com/marketplace/zh-CN/product/custom-dynamic-crosshair-pack
https://youtu.be/cYWxJc07KPY
This pack contains :
- 6 different shapes : square, triangle, circle, graduation, cross, dot.
- Many customisation features : radius, thickness, primary color (white color), secondary color (grey color), neon, mask radius, etc...
- 30 material instances presets.
This pack can be use in fps, rts, and other type of games. it can be rotated, and transform with widget element.
Full generated material, it's not based on any image, with high precision which prevents any multi-resolution deform problem.
This pack is perfectly suited for hit marker and movements effects.
If you want an upgrade with any additional shape, let us know in comments. If many of you are requesting the same thing, then we will do an other pack.
If you want to use the same shape more than once in your instance, check out this video :
技术细节
- 2 user widgets demo.
- 31 material instances.
- 13 material functions which can be reused.
- 5 materials.
- 6 shapes : square, triangle, circle, graduation, cross, dot
Do Materials derive from a Master Material with instances as variation: Yes
Intended platform: Desktop
Documentation: tutorial 1 & tutorial 2
wangzhenmo  发表于 2022-5-25 14:26:30
qq_欣欣_wUj  发表于 2023-6-7 08:43:47
每日一登录,搞点活跃度
梨型胖子 实名
18 小时
阿尔法晶矿 吃鸡头盔 英雄盾 长枪 蓝色史莱姆 长剑
