Blender批量渲染插件 Render+ V2.5
242 1
发布于 2024-3-15 23:48:58
插件类型: Blender
版本信息: V2.5
软件版本要求: 未知或无明确软件版本限制
官网地址: https://blendermarket.com/products/render/
Render+是Blender的一个管理批量渲染插件,不需要复杂的设置,可以选择渲染动画或者单帧、修改摄像机、场景、图层、大小等设置、选择CPU或者GPU渲染等Render+ is a Blender addon that makes batch rendering easy.I wrote this addon because I wanted to automate more of my workflow without having to fiddle with scripts and complicated settings. Render+ is designed to put as much power in your hands with the simplest interface possible.
  • Render animations or still images at custom frames or ranges.
  • Change world, camera, scene, view layer and size for each job.
  • Render from external blend files (and add them in bulk too)
  • Setup a different GPU for each job, the CPU or all devices
  • Run a shell command before and after rendering (for both the batch and each render job)
支持的Blender版本:
  • Blender 2.8, 2.81, 2.82, 2.83, 2.9, 2.91, 2.92, 2.93, 3.0
安装步骤:
  • 将Render+文件夹复制到Blender安装目录下的addons目录下,比如:C:\Program Files\Blender Foundation\Blender\2.xx\scripts\addons
签名被屏蔽
幸运の兔脚  发表于 2024-2-26 10:36:26
