UE虚幻资源 [模型/材质] Cartoon Water Shader虚幻4UE4卡通河边小屋彩虹场景
196
3
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 模型|贴图
价格:50元素币(或5余额) 百度网盘 销售总额:100元素币 购买人数:2
官网链接:https://unrealengine.com/marketplace/zh-CN/product/cartoon-water-shader
技术细节
Features:
• Gerstner Waves
• Buoyancy
• Underwater
• Stencil Mask (no water inside of the boat)
• Caustic and wet sand effect
• Spline based river editor
• Wave resistance around objects in the river
• Foam around intersecting objects
• Surface Highlights
• Water Depth with custom colors
• Refraction
• Waterfall
• Light Angle based fake SSS
• Highly customizable
• Tile Repeat Solver Material Function
• Waterline for ocean and lake
Supported Platform:
• Windows (The shader requires DirectX 11 or above)
How to use:
• You should turn on Mesh distance field in Project settings\Engine\Rendering\Lighting\Generate Mesh Distance Field to enjoy the wave resistance around objects in the river and foam intersections. Your Engine Scalability Shadow's setting also has to be higher than medium! Your water will be white if you not do this!
• You should change the Custom Depth-Stencil pass value to Enabled with Stencil in Project settings\Engine\Rendering\Postprocessing. If you not do this your boat will be filled with water!
• You must place at least 1 static object into your scene which generates mesh distance fields! The position of the mesh is irrelevant and it could be a default box.
• For River drop the BP_CartoonWater_RiverTool into your level and scale to desired size, select a spline point hold ALT and move simultaneously to add a new spline point
• For Ocean drop the BP_CartoonWater_Ocean into your level and scale to desired size
• For Lakes drop the BP_CartoonWater_Lake into your level and scale to desired size
3D小白白  发表于 2022-7-6 16:31:28
感谢大佬分享
哒哒的达达  发表于 2022-7-19 11:12:21
缺少关卡
オーロラ  发表于 2023-2-23 18:40:33
这个好这个好
Ouroborix 实名
21 小时
元素季卡 阿尔法晶矿 吃鸡头盔 枫月药水 【绝】黄金项链 英雄盾 扩散者 元素巨无霸 长剑 元素金币 六维几何 长枪 长剑
