ZBrush相机参考多角度定位保存切换插件-ZBrush Plugin Ref Switcher
205 1
发布于 2023-6-21 19:23:43
A站链接:https://www.artstation.com/marke ... plugin-ref-switcher
Switch the references paired with the custom camera angles with one hotkey!
Compatibility:
From ZBrush 2019 64 bit and higher
Installation:
Extract RefSwitcher.ZIP to \Pixologic\ZBrush 20XX\ZStartup\ZPlugs64
Restart Zbrush
The Ref Switcher will appear in the Zplugins panel.
Release Notes
Relase 1.3
Fixed Bugs:
Auto switching to the last project.
Incorrect camera loading with the close zoom.
Note: Relase 1.3 will not support the previos saved views.
Relase 1.3.1
Quick fix for flipped camera bug
Relase 1.3.2
Support from ZBrush 2019
兼容性:
来自ZBrush 2019 64位及更高版本
安装:
将RefSwitcher.ZIP提取到\Pixologic\ZBrush 20XX\ZStartup\ZPlugs64
重新启动Zbrush
Ref Switcher将出现在Zplugins面板中。
发行说明
继电器1.3
修复的错误:
自动切换到上一个项目。
近距离变焦时相机加载不正确。
注意:Relase 1.3不支持以前保存的视图。
继电器1.3.1
快速修复翻转相机错误
继电器1.3.2
