Easy Mesh ZBrush Plugin- 插件
634 17
发布于 2023-9-22 19:30:19
价格:123元素币(或12余额) 百度网盘 销售总额:123元素币 购买人数:1
尊敬的游客 ,本内容需要支付 123元素币十分之一的[余额] 来购买.
A站链接:https://www.artstation.com/marke ... -mesh-zbrush-plugin
Easy Mesh has all the tools you need at hand, for grouping, masking, building great meshes, and fixing common problems.
A must have for every ZBrush modeler!
Easy Mesh allows you to fix, optimize and reorganize your 3D meshes easy and fast. In addition, it is also a great tool for saving time when modeling.
The interface is divided in three sections:
- \'Mesh Fix\' contains the \'Easy Mesh Fix\' button and a set of switches. Each one of them does a task. You can select which ones to apply, and click the button, and it will do all of them.
- \'Weld & Delete\' can join and split parts of the mesh, and delete unwanted parts.
- \'Group & Zremesh\' is for working with groups and Zremesher together to get a perfect topology.
What can you do with Easy Mesh?
- Fix common problems in your meshes
- Check the normals and flip them
- Merge, split and delete parts of the mesh easily
- Make and modify your polygroups faster and easier
- Select and delete unwanted parts in seconds
- Save time when making clothing or other meshes made with Extract and Zremesher
- Get perfect masks with quick access to masking tools and grouping
- Use the exclusive \"Grow and Group\" button for selecting parts and making groups faster and better
In a neat and practical interface, you find the tools that you need for making clean meshes and saving lots of time, while letting you concentrate in your project.
在简洁实用的界面中,您可以找到制作干净网格和节省大量时间所需的工具,同时让您专注于项目。
Easy Mesh 拥有您需要的所有工具,用于分组、遮罩、构建出色的网格和修复常见问题。
每个 ZBrush 建模师都必须拥有!
Easy Mesh 允许您轻松快速地 修复、 优化和重新组织您的 3D 网格。此外,它也是节省建模时间的好工具。
该界面分为三个部分:
- “Mesh Fix” 包含“Easy Mesh Fix”按钮和一组开关。他们每个人都完成一项任务。您可以选择要应用的那些,然后单击按钮,它将完成所有这些。
- “焊接和删除”可以连接和分割网格的部分,并删除不需要的部分。
- \'Group & Zremesh\' 用于与组和 Zremesher 一起工作以获得完美的拓扑。
您可以使用 Easy Mesh 做什么?
-修复 网格中的常见问题
- 检查法线 并翻转它们
- 轻松合并、拆分和删除部分网格 - 更快、更轻松地
制作和修改多组
-在几秒钟内 选择和删除不需要的部分
-制作服装或其他网格时节省时间使用 Extract 和 Zremesher - 通过快速访问遮罩工具和分组
获得完美的遮罩- 使用独有的“增长和分组”按钮来选择部件并更快更好地制作组
参与人数 3元素币 +35 活跃度 +17 展开 理由
苏鱼 + 11 + 7 好帖子
kazami0620 + 8 + 1 这是我能看的吗?
悠扬的G调... + 16 + 9 现在都这么卷了吗?
little219  发表于 2023-2-3 23:00:15
nice plugin
nice plugin
b877168688  发表于 2023-2-4 11:02:49
齐济沧海  发表于 2023-2-6 09:44:43
nice !
772318019  发表于 2023-2-9 01:31:33
啥意思?这软件啥功能
王大帅  发表于 2023-2-17 09:51:00
多莫西  发表于 2023-2-26 12:03:58
好用不
宸宇  发表于 2023-5-7 10:11:09
过于优秀,拒接评论
狂奔de蜗牛  发表于 2023-5-30 20:43:13
zsj1208  发表于 2023-6-2 14:28:15
怎么安装
吱吱只  发表于 2023-7-4 10:37:30
狂奔de蜗牛  发表于 2023-8-2 09:41:42
禁止开火车  发表于 2023-8-12 09:52:41
17#
每天一早上元素,挖矿撩妹两不误
morrison75  发表于 2025-9-11 10:10:43
18#
每天一早上元素,挖矿撩妹两不误
