画笔资源 [3D画笔] Jewelry Chains Maker 250 ZBrush Curve IMM Brushes - Standard License珠宝链笔刷
1409
3
价格:350元素币(或35余额) 百度网盘 销售总额:4550元素币 购买人数:13
尊敬的游客 ,本内容需要支付 350元素币十分之一的[余额] 来购买.
A站链接:https://www.artstation.com/marke ... h-curve-imm-brushes
Jewelry Chains Maker is a complete pack of brushes for ZBrush that contains all that you need to add fine jewelry chains to your 3D models.
It includes several kinds of jewelry chains, like rolo chains, figaro chains, box chains, oval links, figure 8 chains, triangles, circles, hearts, pearls, beads, square links, flowers, bells, and more.They come in two versions, with clasp, and without it. They work for male and female characters.
You can use them for adding jewelry to your characters, or for thieves scenes, jewelry stores modeling, treasures, and much more. They can be used alone, or as chains for your medallions or other jewelry pieces, saving you a lot of time.
A must have for jewelry chains with ZBrush!
FEATURES:
250 ZBrush curve IMM brushes: 125 with clasp, and 125 without clasp.
Many different kinds of chains: rolo chains, figaro chains, box chains, oval links, figure 8 chains, triangles, circles, hearts, pearls, beads, square links, flowers, bells, and more.
A PDF tutorial, that tells you how to use the brushes, and how to adjust the clasp, and tips and tricks.
PDF index of the brushes to choose them easier.
A video tutorial, that you can also find on YouTube (in our channel), but is included in our product for your future reference.
Jewelry Chains Maker 是一个完整的 ZBrush 画笔包,包含将精美珠宝链添加到 3D 模型所需的一切。
它包括多种珠宝链,如 rolo 链、figaro 链、盒子链、椭圆链、8 字形链、三角形、圆形、心形、珍珠、珠子、方形链、花朵、铃铛等。它们有两个版本,有扣子,没有它。他们为男性和女性角色工作。
您可以使用它们为 您的角色添加珠宝,或用于 盗贼场景、珠宝店造型、宝藏等等。它们可以单独使用,也可以用作奖章或其他珠宝首饰的链条,为您节省大量时间。
ZBrush珠宝链的必备品!
特征:
250 个 ZBrush 曲线 IMM 刷子:125 个带扣,125 个不带扣。
许多不同种类的链:rolo 链、figaro 链、盒形链、椭圆链、8 字形链、三角形、圆形、心形、珍珠、珠子、方形链、花朵、铃铛等等。
一个PDF 教程,告诉您如何使用画笔、如何调整表扣以及提示和技巧。
画笔的PDF 索引使选择它们更容易。
视频教程,您也可以在 YouTube(在我们的频道中)找到,但包含在我们的产品中以供您将来参考。
参与人数 3 元素币 +16 活跃度 +6
花落  发表于 2023-7-27 08:15:09
帮帮顶顶!!
gmcc020322  发表于 2023-7-28 14:17:52
阿浩1989  发表于 2023-11-7 11:31:02
资源哪里好,肯定元素找~
wq3708 实名
18 小时
友情药水 长剑 青色史莱姆 吃鸡头盔 白晶石 长枪 水晶剑 元素巨无霸 元素季卡 紫色药水 元素金币 双杀
