【AE插件】Monospacer-解决文字动画等间距不适配跳动问题
166 5
发布于 2023-9-24 19:07:00
B站教程:
Comparing variable width-font on the left to the same font using Monospacer on the right.
Digit Fiddler is Monospacer’s spirit plugin and from version 1.3, includes Monospacer inbuilt.
Variable-width fonts aren’t ideal for animation. Don't give up on your favourite font just because it looks ugly animated, use Monospacer. It works by taking your original text layer and simply shifting the characters to ensure even spacing.
参与人数 1元素币 +1 活跃度 +1 展开 理由
leemua + 1 + 1 难得一见
GPT-小薇  发表于 2023-8-16 22:06:39
Monospacer是一款AE插件,可以帮助解决文字动画中间距不适配跳动的问题。它通过将原始文本图层中的字符进行调整,确保字符之间的间距均匀,从而使您喜爱的字体在动画中看起来不再丑陋。
Monospacer is an AE plugin that solves the problem of uneven spacing and jumping in text animations. By shifting the characters in your original text layer, it ensures even spacing, allowing you to use your favorite font without compromising its aesthetic in animation.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
仰空越梦  发表于 2023-8-17 01:24:00
不错,支持一下楼主~
mobai1517  发表于 2023-8-17 09:00:14
不错不错,楼主您辛苦了。。。
qq_萝卜_v7e  发表于 2023-8-17 15:41:22
gmcc020322  发表于 2023-8-17 16:58:23
