【AE脚本】TypeMonkeycn-翻转字幕倒鸭子脚本
408 4
发布于 2023-9-25 13:06:47
提取码:72p1
B站教程:
Key features
  • Creates random kinetic type layouts based on parameters entered into the control panel.
  • Keyframeless timeline makes changes to timing as simple as sliding a marker.
  • Creates a parented camera that points to each successive word as it transitions on.
  • Distributes words evenly over the length of the composition or work area.
  • Manual adjustments are easily made to size, position, rotation, and opacity.
  • Features a wide range of type transitions randomly selected by default, but can be specified as well.
  • Marker Sync feature allows for push-button alignment with preexisting marker layers, making syncing to music a breeze.
  • Allows for different interpolation for camera movement, auto-rotate, and auto frame.
  • Automatically builds and cleans to facilitate easy experimentation.
  • Now supports motion blur and preset load and save.
  • Kuler color palettes are now easily imported.
  • Support for 3rd party TextMods (sold separately), these can add support for Right to Left languages as well as other fun text modifications.
  • Check out the available TextMods: Arabic Text and Hebrew Text.
  • Free: Includes MonkeyTools- an ongoing collection of utilities specifically written to enhance the functionality of the Monkey Suite. Includes: UnShy Selected Layers, UnShy Text/Image Layers, UnShy Control Layers, Reset View, Invert Locks, Unlock All, Lock All, Scene Maker, Remove Duplicate Markers (to clean up Premiere-generated marker layers, Lock Children & Lock, Parents.) You find MonkeyTools in the same place as your main Monkey download
*Note to users interested in syncing text to audio as demonstrated in several tuts, the Content Analyse feature is no longer supported by Premiere Pro. We recommend using Textsyncr, a great script here on aescript.com
参与人数 2元素币 +17 活跃度 +6 展开 理由
淼煮鱼 + 7 + 5 前排留名
angelanany... + 10 + 1 看上去好像还行
GPT-虚拟人18号  发表于 2023-8-17 21:52:42
TypeMonkeycn-翻转字幕倒鸭子脚本是一款AE脚本,可以根据输入到控制面板中的参数创建随机的动力学排版布局。它具有无关键帧的时间轴,使得对时间进行调整变得简单。脚本会创建一个与每个字词的过渡相对应的相机。可以将字词均匀分布在合成或工作区的长度上。可以轻松调整大小、位置、旋转和不透明度。默认情况下,它具有广泛的随机选择的类型过渡效果,但也可以自定义指定。Marker Sync功能可以轻松地与现有的标记图层对齐,使得与音乐同步变得轻而易举。支持不同的插值方式来进行相机运动、自动旋转和自动帧。自动构建和清理以便进行简单的实验。现在支持运动模糊和预设的导入和保存。可以轻松导入Kuler色彩调色板。还可以支持第三方TextMods(需单独购买),这些可以支持从右到左的语言以及其他有趣的文本修改。请查看可用的TextMods:阿拉伯文本和希伯来文本。免费版本包括MonkeyTools-一套持续更新的工具集,专门用于增强Monkey Suite的功能。包括:UnShy Selected Layers、UnShy Text/Image Layers、 UnShy Control Layers、Reset View、Invert Locks、Unlock All、Lock All、Scene Maker、Remove Duplicate Markers(用于清除Premiere生成的标记图层)、Lock Children和Lock Parents。你可以在与主要Monkey下载相同的位置找到MonkeyTools。*对于有兴趣将文本与音频同步的用户,请注意,《Premiere Pro》不再支持Content Analyse功能。我们推荐使用Textsyncr,这是一个在aescript.com上非常好用的脚本。
TypeMonkeycn-Flip Subtitle Duck Script is an AE script that creates random kinetic type layouts based on parameters entered into the control panel. It has a keyframeless timeline, making it easy to make timing changes. The script creates a parented camera that points to each word as it transitions. Words can be distributed evenly over the length of the composition or work area. Manual adjustments can be made to size, position, rotation, and opacity. It features a wide range of randomly selected type transitions, but can also be specified. The Marker Sync feature allows for alignment with preexisting marker layers, making syncing to music easy. Different interpolation can be applied to camera movement, auto-rotate, and auto frame. It automatically builds and cleans up to facilitate easy experimentation. Motion blur and preset load and save are supported. Kuler color palettes can be easily imported. It also supports 3rd party TextMods (sold separately) that add support for Right to Left languages and other text modifications. There is a collection of utilities called MonkeyTools included for free, which enhance the functionality of the Monkey Suite. Please note that the Content Analyse feature for syncing text to audio is no longer supported by Premiere Pro, and Textsyncr is recommended as an alternative script available on aescript.com.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
仰空越梦  发表于 2023-8-18 00:33:21
我们先定一个小目标~比如一天挖一吨元素币
mobai1517  发表于 2023-8-18 07:30:10
已阅,优秀
mobai1517  发表于 2023-8-18 12:18:34
学习了
