【AE插件】Path Visualizer-遮罩MASK路径可视化效果AE插件
243 4
发布于 2023-10-3 21:20:44
链接:https://pan.baidu.com/s/1rRSZUvoM41huLpq4BwLjGg?pwd=57en
提取码:57en
油管链接:(1) Path Visualizer New Plugin for After Effects Available now - YouTube
Show off your curves with Path Visualizer
Path Visualizer draws vertices, beziers and handles based on your text or paths. It updates live with any animations. Great for technical/blueprint styles or just showing off your phat curves.
Features:
  • Compatible with text, shape layers and masks
  • Updates live with animation
  • Different vertex types: Circle, diamond, square
  • Customize handle lengths, widths, colors, stroke
  • Easy to use animation system
  • Large number of stylistic parameters, customizable to suit any style
  • Left: Path Visualizer adapts to the scale of your text/path, allowing you to scale infinitely without loss of resolution.
插件特性:
与文本、形状层和MASK遮罩兼容
动画实时更新
不同顶点类型:圆、菱形、正方形
自定义手柄长度、宽度、颜色、笔划
易于使用的动画系统
大量StyleStc参数,可自定义以适合任何样式
路径可视化工具根据文本/路径的比例进行调整,允许您无限缩放而不丢失分辨率
参与人数 2元素币 +11 活跃度 +4 展开 理由
xunmixunmi + 9 + 2 就离谱
jinMenShan... + 2 + 2 看看
wujigs  发表于 2023-8-20 09:45:19
前排支持
花落  发表于 2023-8-20 17:30:59
谢谢楼主
Teny  发表于 2023-8-21 20:41:49
谢谢楼主分享!!!
仰空越梦  发表于 2023-8-23 11:39:12
谢谢楼主分享!!~
