【Blender插件】Fluid Painter 1.2.21-轻松绘制流体工具
109 7
发布于 2024-2-18 18:39:00
链接:https://pan.baidu.com/s/1dyZN45EISiQT2rLF7LP7Pw?pwd=5lfb 提取码:5lfb
youtube:https://www.youtube.com/watch?v=FtqvakIKfxQ&t
What is Fluid Painter
Imagine effortlessly painting fluids over any surface in your 3D designs. No more tedious workarounds or clunky interfaces – just pure, seamless creativity. That's the power of the Fluid Painter Add-on for Blender. As a 3D artist myself, I was frustrated by the limitations of existing methods. That's why I set out to create a product that would make it easier to work with fluids in 3D design. I tested it myself, and with the help of other 3D professionals, to ensure it was easy to use, flexible, and powerful. And now, I'm excited to share it with you. With Fluid Painter, you'll be able to turn your vision into reality and take your designs to the next level. So go ahead, unleash your creativity and make a splash with Fluid Painter!
Fluid and Fluid+ presets
Fluid Painter provides two primary preset types: Fluid presets, which are great for general painting and recommended for creating fluid leaks. Fluid+ presets are more advanced, dynamically adjusting to the painting surface. However, they require an assigned drawing surface. This assignment is automatically performed by selecting one or more objects just before adding a Fluid+ preset.
Fluid PresetFluid+ Preset
Draws over any 3D surfaceYes
Yes
Recommended for leaking fluidsYesNo
Flattens onto the drawing surface
No
Yes
Needs a drawing object assignedNo
Yes
Features
Fluid Painter is a Blender tool that uses Geometry Nodes to let you easily paint static fluids over any 3D surface using a curve. With base and advanced parameters, you can create custom fluids that fit your exact needs.
  • Easy to use!
    Simply add and draw one of the included presets to quickly create stunning fluid effects.
  • 30+ Presets
    Using the included presets library compatible with both Eevee and Cycles, you can add fluids to your scene in seconds.
  • Drop System
    Fluid Painter features an intuitive drop system that creates a drop at the end of each shape of the fluid curve. You can adjust the size, length, and curvature of the drops and move them along the splines to create a flow effect.
  • Scattering Objects
    The tool also includes two layers of spheres or cylinders that can be added inside or over the surface of the fluid, to simulate for example air bubbles or sugary, adding even more realism to your scene.
  • Advanced Parameters
    Fluid+ presets offer a set of special settings that allow for the creation of flat fluids that better adapt to the drawing surface!​
  • Export to any 3d software
    Want to use the fluid you created outside Blender? It's easy! Convert to mesh and export!
  • Make your own fluid
    Build your fluid from scratch using the included default presets, the limit is just your fantasy!
Presets List
  • Biscuit
  • Blood+
  • Chocolate Brown
  • Chocolate White
  • Default Fluid
  • Default Fluid+
  • Donut
  • Foam
  • Glaze
  • Glaze+
  • Glitter
  • Gummy
  • Honey
  • Honey+
  • Ketchup
  • Lube
  • Maple Syrup
  • Maple Syrup+
  • Mayo
  • Metal Gold
  • Metal Silver
  • Milk
  • Milk+
  • Mud+
  • Mustard
  • Oil Crude+
  • Oil
  • Slime
  • Slime Glowing
  • Soap
  • Soap+
  • Water Drops
  • Water Drops Animated
  • Water+
  • Wax
参与人数 2元素币 +19 活跃度 +6 展开 理由
lzf123qw + 9 + 4 【点赞】这很有大网气质!
monkeyhaha + 10 + 2 每天一早上元素,挖矿撩妹两不误。
pyykk  发表于 2024-1-24 21:46:22
好好 学习了 确实不错
仰空越梦  发表于 2024-1-25 00:19:26
谢谢楼主分享!
mome  发表于 2024-1-25 16:00:51
不错不错,楼主您辛苦了。。。
焱相燕  发表于 2024-1-25 20:01:11
这很元素!
