【Blender插件】Windy v1.0-逼真场景风效果微风吹过飘动插件
92 3
发布于 2024-3-2 13:51:28
插件类型: Blender
版本信息: v1.0
软件版本要求: Blender 3.0, 3.1, 3.2, 3.3, 3.4, 3.5, 3.6, 4.0
官网地址: https://blendermarket.com/products/windy
油管:https://www.youtube.com/watch?v=5iNCTVhW__U
Windy: is a addon to add into your scene wind effect giving you instant realistic wind effect without losing time tweaking many parameters until achieve the desired effect each time you want to add wind! With this addon you can also save your presets of your wind configuration and you can change between each preset in in real-time, or create animations.
Blender Version Supported: Also work with the the upcoming Blender 4.0
Installation:
Go to Edit > Preferences >1-     Choose Install and select the windy.zip file
2-     Activate it
3-     In the side Panel you should have now a tab with the name Windy where all the tools will be available.
Create Wind:
Add into your scene the wind system ready to simulate realistic wind! The system is added where the 3d cursor is located.
Delete Windy:
Remove completely the wind system from your scene.
Wind Strength:
Controls the wind intensity in the scene
Turbulence Strength:
Controls the wind turbulence amount for the scene
FreqZ Strength:
Controls the intensity of the wind | turbulence animation
FreqZ Scale:
Controls the speed of the wind | turbulence animation
Presets:
You can save multiple wind presets and change them in real-time or create animations.
参与人数 2元素币 +18 活跃度 +7 展开 理由
拷给你 + 8 + 4 好帖子
zhangting1... + 10 + 3 首发必发微元素,荣耀加身装备酷。
枫玮东赐  发表于 2024-2-6 06:30:03
必须支持
famcn  发表于 2024-2-6 12:00:43
好好 学习了 确实不错
