element3ds.com
SD-材质作品 Marble _amp; Gold Trim Sheet - With Examples - 100_ Substance Designer
760
1
[翻译] : Marble &黄金镶边贴图 - 示例 - 100 Substance Designer 我为客户制作的镶边贴图,并对其做了一些改动和优化,这是它的变体版本。之前我做的大部分优秀镶边贴图都在保密协议下,这是我第一次在这里分享。这个我使用平面和圆盘网格进行了非常简单快速的UV映射。仅用两张甚至一张镶边贴图,就能创造出整个环境。在评论中告诉我你的想法。
Trim Sheet material I made for a client & made some changes & improvements for a bit of a variated version which you can see here, Most of the good trim sheet work I did before is under NDA, first time I post a trim sheet work here.  This one I used a plane & disk meshes to do very simple & quick UV-ing, we can create a whole environment with just two trim sheets or even one sometimes. Let me know what you think in the comments.
A站:https://www.artstation.com/abderrezakbouhedda
回复
lpzyuan  发表于 2025-1-31 02:26:37
Abderrezak 实名
Material & Shader Artist (
