element3ds.com
【综合_2D_3D资源】 Obi Rope Latest Version 4.1 unity3d asset
158
1
With Obi Rope you can create ropes in a matter of seconds, with complete control over their shape and behavior. The ropes can collide with the environment and with each other, and can be attached to rigid bodies.
New in 4.0: ObiRods and the new oriented particle technology allow you to create realistic cables that can be twisted along their length and set to remember their initial shape.
This system is NOT based on rigid bodies and joints, unlike other rope solutions. This is based on Obi particles, which makes it more lightweight, detailed, and unconditionally stable.
Available for Windows, Mac, iOS and Android.
Features:
- Procedural smooth mesh generation using splines, complete with tangent space updating and normal map support. No need to manually generate geometry for your ropes.
- Change rope length at runtime. - Tearable/cuttable rope. - Closed loops. - Two-way rigid body interaction.
- Modular solver: don't waste performance, only use the constraints your rope needs.
- Per module adjustable solver iteration count.
- Bending constraints.
- Per particle pin constraints.
- In-editor simulation preview.
- Easy-to-use editor particle tools: selection, brush selection, paintbrush, property smoothing...
- Simulation state gets serialized -> save your ropes mid-simulation->instantiate them already warm-started.
- Supports all standard Unity colliders.
- Automatic camera culling: non-visible ropes do not update their simulation.
价格:30元素币(或3余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 30元素币十分之一的[余额] 来购买.
参与人数 2 活跃度 +16
mryu9958  发表于 2019-10-31 11:08:22
这次来看看东西好不好
Alphaneo 实名
9 小时
长枪
