[Unity] Time.time 时间
查看:663 |回复:3 | 2015-4-6 11:20:30
Time.time 时间
static var time : float
Description描述
The time this frame has started (Read Only). This is the time in seconds since the start of the game.
此帧开始的时间(只读)。这是以秒计算到游戏开始的时间。也就是说,从游戏开始到到现在所用的时间。
When called from inside MonoBehaviour's FixedUpdate, returns fixedTime property.
当在MonoBehaviour的FixedUpdate里调用的时候,返回的是fixedTime属性。
C#JavaScript
// Instantiates a projectile off every 0.5 seconds,
// if the Fire1 button (default is ctrl) is pressed.
//如果Fire1按钮被按下(默认为ctrl),每0.5秒实例化一发子弹
var projectile : GameObject;
var fireRate = 0.5;
private var nextFire = 0.0;
function Update () {
        if (Input.GetButton ("Fire1") && Time.time > nextFire) {
                nextFire = Time.time + fireRate;
                var clone = Instantiate (projectile, transform.position, transform.rotation);
2015-4-6 11:20:30
3个回答,把该问题分享到群,邀请大神一起回答。
2018-10-20 20:50:12   回复
资源哪里好,肯定元素找!
2018-10-20 21:12:12   回复
2018-10-20 21:41:56   回复
Unity3D技术手机游戏引擎手游引擎
