AE文字导出至Word修改脚本 Aescripts Text2Spreadsheet V1.8.002
86 2
发布于 2023-5-31 20:23:22
Text2Spreadsheet可以将AE里的文字导入到 Office,Excel或者 Apple Numbers ,通过修改后可以重新导入AE中
Text2Spreadsheet exports the texts of your After Effects project to a spreadsheet where you can modify them easily with applications like Microsoft Excel, Apple Numbers or Open Office. When you are done editing, you can apply the changes to your After Effects project in a single click.
Text2Spreadsheet exports the text from your After Effects project to a spreadsheet where you can easily modify it with applications like Microsoft Excel, Google Docs, Apple Numbers or Open Office. When you are done editing, you can apply the changes to your After Effects project in a single click.
The spreadsheets are easy to read and also support several versions of your text. Perfect for translating your projects into different languages, or sending text to your client for review.
Featuresimport and export with a single click
There's no need to rename or otherwise mark the layers that you want to export to the spreadsheet.
simple tables
古今多少事,都付笑谈中
逆水寒  发表于 2022-6-10 21:43:37
enjoylin813  发表于 2022-10-17 17:58:39
可以可以,感谢分享
