maya
插件 234 4
发布于 2023-8-28 16:46:50
CallAMTNormalToolLT;
global proc CallAMTNormalToolLT() {
string $AMTNormalPath = (`internalVar -userScriptDir`) + "AMTNormalsLT/";
string $AMTNormalsLT = "AMTNormalToolLT";
if ( `window -exists $AMTNormalsLT` ) { deleteUI $AMTNormalsLT; windowPref -remove $AMTNormalsLT;}
// windowPref -remove $AMTNormalsLT;
// windowPref -query -widthHeight $AMTNormalsLT; //real window size.
window -title "AMT Normal Tools LT 1.0" -s true -wh 257 188 -bgc  (45/255.0) (50/255.0) (55/255.0)
            -mxb false -tlb true $AMTNormalsLT;
string $FaceWeightOps = `frameLayout -cll 0 -label "FACE WEIGHTED WORKFLOW" -labelVisible false`;
rowColumnLayout -numberOfRows 1;
button -l "Weight Face Normals" -command ("PickLTOperation")
             -bgc  (26/255.0) (30/255.0) (32/255.0) -h 30 -w 255;
setParent ..;
separator -h 1 -st "in" -hr 1;
iconTextButton -style "iconAndTextHorizontal"
    -image ($AMTNormalPath + "Vertex_Display.png")
    -font "boldLabelFont"
    -ann "Enabled"
    -label "Vertex Display"
    -w 125
    -command ("setPolygonDisplaySettings(\"vNormal\")") VertexDisplayBTN;
    -image ($AMTNormalPath + "Face_Display.png")
    -ann "Enabled"
    -label "Face Display"
    -w 125
    -command ("setPolygonDisplaySettings(\"fNormal\")") FaceDisplayBTN;
setParent..;
    -image ($AMTNormalPath + "SelectHard.png")
    -ann ""
     -w 125
    -label "Sel. Hard Edges"
    -command ("SelectHardEdges") SelectHardBTN;
    -image ($AMTNormalPath + "SelectSoft.png")
    -ann ""
     -w 125
    -label "Sel. Soft Edges"
    -command ("SelectSoftdges") SelectSoftBTN;
setParent..;
text -fn "boldLabelFont" -label "Normals Display Size";
float $NSizeValue[] = `polyOptions -q -sn`;
floatSliderGrp
     -field true
    -minValue -0 -maxValue 250.0
    -fieldMinValue 0 -fieldMaxValue 1000
    -value $NSizeValue[0]
    -cw 1 50
    -dc ("ModifyNormalSize")
    -cc ("ModifyNormalSize")
    -cal 1 "center" NormalSizeSLDR;
setParent $FaceWeightOps;
showWindow;
global proc EditBevelAttr() {
string $Source_Mesh[] = `ls -sl -fl`;
string $CurrentShape[] = `ls -sl -dag -o -fl -lf`;
string $OBJSel[] = stringArrayRemoveDuplicates(`listRelatives -p -path $CurrentShape`);
string $GetBevel[] = stringArrayRemoveDuplicates(`listConnections -scn true -d true
            -t "polyBevel3" -et true $CurrentShape[0]`);
if( `dragAttrContext -exists "NormalsAttrCtx" ` ) { dragAttrContext -reset; }
else { dragAttrContext NormalsAttrCtx; }
dragAttrContext -edit
-connectTo ($GetBevel[0] + ".fraction" + "\n")
NormalsAttrCtx;
setToolTo NormalsAttrCtx;
global proc ModifyNormalSize() {
float $GetSLDRVal = ` floatSliderGrp -q -v NormalSizeSLDR`;
polyOptions -sn $GetSLDRVal;
global proc DisplayVNormals() {
string $GetStat = `iconTextButton -q -ann VertexDisplayBTN`;
string $GetStatF = `iconTextButton -q -ann FaceDisplayBTN`;
if ($GetStat == "Disabled") { polyOptions -displayNormal true; polyOptions -pt;
iconTextButton -e -ann "Enabled" VertexDisplayBTN;
if ($GetStatF == "Enabled") { polyOptions -pf; }
else if ($GetStat == "Enabled") { polyOptions -displayNormal false; polyOptions -pt;
iconTextButton -e -ann "Disabled" VertexDisplayBTN;
global proc SelectHardEdges() {
resetPolySelectConstraint; polySelectConstraint -m 3 -t 0x8000 -sm 1; polySelectConstraint -m 0;
global proc SelectSoftdges() {
resetPolySelectConstraint; polySelectConstraint -m 3 -t 0x8000 -sm 2; polySelectConstraint -m 0;
global proc VariableShadowDisable() {
    if (`exists melOptions`) { melOptions -duplicateVariableWarnings off;}
global proc FWVNLT() {
int $IsFace = size(`filterExpand -sm 34`);
int $IsPolygon = size(`filterExpand -sm 12`);
if ( ($IsPolygon >= 1) && ($IsFace == 0) ) {
if (size($GetBevel) == 0) {
$GetBevel = `polyBevel3 -fraction 0.1 -offsetAsFraction 0 -segments 1
     -worldSpace true -fillNgons true -mergeVertices true -offset 0.01
     -mergeVertexTolerance 0.0001 -smoothingAngle 180 -miteringAngle 180
     -angleTolerance 180 -ch true `;
polySoftEdge -a 180 -ch 1 $OBJSel;
polyNormalPerVertex -fn true $OBJSel;
setAttr ($GetBevel[0] + ".offsetAsFraction") 1;
select $OBJSel;
EditBevelAttr;
else {
setAttr ($GetBevel[0] + ".offsetAsFraction") 0;
setAttr ($GetBevel[0] + ".offset") 0.01;
select $OBJSel;
EditBevelAttr;
else if ( ($IsPolygon == 0) && ($IsFace >= 1) ) {
string $TargetFaces[] = `ls -sl -fl`;
for ($Face in $TargetFaces) {
string $faceNormal[] = `polyInfo -fn $Face`;
$array = stringToStringArray($faceNormal[0], " ");
float $X = $array[2];
float $Y = $array[3];
float $Z = $array[4];
string $TargetVerts[] = `polyListComponentConversion -ff -tv $Face`;
polyNormalPerVertex -xyz $X $Y $Z $TargetVerts;
else { warning "Hmmm, you don't seem to have a mesh selected. Dafuk ?!"; }
global proc PickLTOperation() {
  int $GetOperand = `getModifiers`;
  if ( $GetOperand == 0 ) { FWVNLT(); }
  else if ( $GetOperand == 4 ) {
$AMTNormalsLTHelper = "LTHelper";
string $AMTNormalHelper = (`internalVar -userScriptDir`) + "AMTNormalsLT/DocHelper.png";
// if ( `window -exists $AMTNormalsLTHelper` ) { deleteUI $AMTNormalsLTHelper; windowPref -remove $AMTNormalsLTHelper; }
if ( `window -exists $AMTNormalsLTHelper` ) { deleteUI $AMTNormalsLTHelper;}
window -title "AMT Helper Tool"  -s true -mxb false $AMTNormalsLTHelper;
frameLayout -cll 0 -label "Face Weighted Vertex Normals Guide" -labelVisible true -fn "fixedWidthFont";
columnLayout -adjustableColumn true;
image -image $AMTNormalHelper;
showWindow;
source "AMTNormalsLT/AMTNormalsLT.mel"
参与人数 1元素币 +1 活跃度 +1 展开 理由
jinshan + 1 + 1 千点万点,不如微元素指点。
ltz869878580  发表于 2023-6-13 20:33:18
Teny  发表于 2023-6-13 21:43:48
谢谢楼主分享!!!
gmcc020322  发表于 2023-6-14 14:57:04
看不懂,不知道是啥
