element3ds.com
地编-CG场景 [引擎地编] Modular Dungeon Catacombs Mobile
36812
[翻译] : 模块化地牢墓穴 - 移动版是一个专为艺术家设计的3D艺术包,包含额外的简单快速的植物贴图解决方案,注重模块化和性能。适用于游戏和3D应用的高质量、半写实3D环境艺术包,版本2.0。大部分纹理由Substance Designer制作或手工绘制,几乎无需照片参考材料。主要采用内置渲染管道,内含UPR和HDRP转换包。UPR和HDRP已支持和测试。使用高清渲染管线HDRP和SSGI实时光照渲染,无烘焙过程!
您可以在Unity Asset Store上找到该资源包:https://assetstore.unity.com/packages/3d/environments/dungeons/modular-dungeon-catacombs-mobile-212016
Modular Dungeon Catacombs - Mobile is a 3D art package with additional simple and fast foliage shader solutions for artists, made with modularity and performance in mind.High-quality, semi-realistic 3D environment art package for games and 3D applications version 2.0. Little to no photo source material as most textures are made using Substance Designer or hand-painted.The main pipeline used is the Built-in Render Pipeline, containing URP and HDRP conversion packages inside. URP and HDRP are supported and tested.Rendered in real-time with the high definition render pipeline HDRP and SSGI, nothing is baked!_______________________________You can find the asset pack on the Unity Asset Storehttps//assetstore.unity.com/packages/3d/environments/dungeons/modular-dungeon-catacombs-mobile-212016
参与人数 1 元素币 +4 活跃度 +5
tobyfredson.artstation.com
Toby_Fredson 实名
freelancer artist
