【AE插件】AutoFill v2.0.0-图层边界自动填充路径生长动画
176 18
发布于 2024-4-6 21:03:23
插件类型: 后期插件
版本信息: v2.0.0
软件版本要求: After Effects 2023, 2022, 2021
官网地址: https://aescripts.com/autofill/
B站教程:
V2更新内容:
– MFR原生;巨大的性能提升
– 新的AE 计算缓存具有坚如磐石的稳定性;即时预览(重新模拟按钮已删除)
– 添加了样式生成器;内置多轨合成解决方案
– 30个全新内部预设
– 改进了50个原始 AE 项目文件预设
– 具有直观渐变编辑器的 RGBA 渐变
– 内置质量设置:超级采样、自适应分辨率和智能抗锯齿
– 3 种附加速度图模式;自动速度图重命名为“较慢的近边界”
– 自动填充桥来连接断开的元素
– 用于渲染农场和 CPU 后备的 CPU 和 GPU 管道
Re-engineered from the ground up to take advantage of the latest performance features in After Effects:
  • Supports After Effects Multi-Frame Rendering (MFR) for faster rendering across multiple cores
  • New caching system for smooth real-time previews without resimulating
  • Rock solid stability - no more flickering
  • GPU Accelerated & Apple Silicon Native
Style Builder
  • The Style Builder is your shortcut to producing complex, multi-layered styles
  • Composite, retime, blend, blur, displace and set unique fill types for up to 5 layers within a single instance of AutoFill; the Style Builder is a game-changer
  • OR choose one of our 30 ready made presets in a single click
AutoFill Bridges
  • Generate invisible bridges between disconnected elements with masks that travel with your layer
  • Forget “leaking” or having to set growth points for each individual section
30 Inbuilt Presets + 50 Project File Presets
  • 30 advanced style builder presets you can apply in a single click
  • The 50+ Presets Project file is back, revamped to take advantage of the new features in v2
RGBA Gradients
  • Effortlessly create inctricate gradients with our intuitive gradient UI
  • Retime & seamlessly loop with 3 unique age modes and the repeater pipeline
3 New Speed Map Modes
  • Introducing Shape Based Flow: moulds to the unique curves of your layer giving you the most fluid and intricate results
  • Turbulent Noise: adds natural variance and realism
  • Combine All: Don’t be limited to just one mode, composite them together
Presets On Steroids
We’ve optimised the 50 preset project files that came with AutoFill to take advantage of the new features. Get more than 50% faster render times compared to version 1
参与人数 3元素币 +21 活跃度 +6 展开 理由
lhcppy + 7 + 1 难得一见
longhuioh + 10 + 1 希望多一点楼主这样的人
LJH900505 + 4 + 4 现在都这么卷了吗?
wujigs  发表于 2023-8-16 18:16:05
不错,支持下楼主
仰空越梦  发表于 2023-8-17 01:31:00
不错,支持一下楼主~
『煙滅』  发表于 2023-8-17 09:16:12
支持一下楼主~
狂奔de蜗牛  发表于 2023-8-17 09:48:23
王啊不要癫火啊  发表于 2023-8-17 13:58:54
gmcc020322  发表于 2023-8-17 16:55:40
wanni  发表于 2023-9-21 11:37:37
1
书臣  发表于 2023-9-25 17:15:35
我的天那这个也很像AI的工具呀。非常棒呀。我的版本还是2020的
催眠  发表于 2023-10-4 14:56:55
神蛊温皇  发表于 2023-10-7 10:59:39
有点东西
资深射技师  发表于 2023-10-16 15:31:41
不错
qq_Jacky_M8n  发表于 2023-10-26 11:30:44
老的就很好用
Mr.Nobody  发表于 2023-10-30 16:16:01
666666
狂奔de蜗牛  发表于 2023-11-8 16:56:01
跳起来吃口橙子  发表于 2023-11-24 18:14:58
17#
666
零一  发表于 2024-1-30 11:21:34
18#
看看
man778  发表于 2024-3-7 16:15:47
19#
hhhh
我是懒觉王  发表于 2024-3-27 10:58:30
20#
马克
