【AE插件】AEscripts Textborder-文字边框渐变虚线动画插件
196 4
发布于 2023-9-27 10:31:34
链接:https://pan.baidu.com/s/1xnZYww65MpuIDTAoqfq8PQ?pwd=pks0
提取码:pks0
油管链接:Free Plugin: TextBorder - Availble now on aescripts - YouTube
Features:
  • Expansion (global)
  • Individual expansion (width, height, top, left, bottom, right)
  • Round edges & control which edges are round
  • Solid & Gradient fill
  • Dash options
  • Transform controls to animate the border independently from the text
  • Compatible with motion blur
  • Compatible with inbuilt text animation tools
  • Compatible with paragraph text & vertical text
  • Apply it directly to the text layer, so no need for parenting, mattes or expressions
TextBox is TextBorder's spirit-plugin that also draws a fill for text layers. If you find TextBorder useful then you'll likely love TextBox!
We've added some new features to TextBorder such as gradient fill, dashes, individual expansion, general performance increases and more which will soon be making an appearance in TextBox.
主要功能:
扩展(全局)
个体扩展(宽度,高度,顶部,左侧,底部,右侧)
圆边和控制哪些边是圆的
实心和渐变填充
虚线选项
变换控件以独立于文本为边框设置动画
兼容运动模糊
兼容内置文本动画工具
与段落文字和垂直文字兼容
将其直接应用于文本 层,因此无需父级图层,遮罩或表达式
参与人数 3元素币 +23 活跃度 +14 展开 理由
zhangting1... + 4 + 5 顶起来
meiyihai + 10 + 4 难得一见
phoneix + 9 + 5 都这么卷了吗?
GPT-小薇  发表于 2023-8-18 12:25:26
这是一个有关AE插件的问题。链接中提供了AEscripts Textborder-文字边框渐变虚线动画插件的下载地址,需要输入提取码pks0才能下载。
Translation:
This is a question about AE plugins. The link provides a download address for the AEscripts Textborder-Text Border Gradient Dashed Animation plugin. You need to enter the extraction code "pks0" to download it.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
yukigo  发表于 2023-8-18 16:48:52
沙发!
hejialin  发表于 2023-8-18 21:19:13
必须支持
花落  发表于 2023-8-19 09:30:21
创意不错 !!
