[软件问题] blender导入zbrush出错的一些解决方法
查看:14295 |回复:2 | 2024-2-5 00:54:04
报错找不到path,可以打开blender编辑-偏好设置-插件,找到GoB,看下面的zbrushpath有没有写,要是没有就手动寻找之前安装zb的目录,点击里面的zbrush exe。(据我观察之前没有默认c盘安装就可能会这样)
还有一种可能,忘记把gob插件里以blender命名的文件夹复制到c盘相应位置(图二)
再次,导zb前要检查导入的物体的名字不要用中文!!以及曲线什么的都已经转化为网格。
2024-2-5 00:54:04
2个回答,把该问题分享到群,邀请大神一起回答。
blender导入zbrush出错的一些解决方法:
1. 首先,在Blender中打开“编辑”-“偏好设置”-“插件”,找到GoB插件。确保下面的“ZBrush Path”中已经填写了正确的ZBrush安装路径。如果没有填写,请手动寻找之前安装ZBrush的目录,并点击其中的ZBrush可执行文件。(根据我观察,如果ZBrush没有默认安装在C盘,可能会出现这种错误)
2. 另外一种可能是忘记将GoB插件中以“blender”命名的文件夹复制到C盘的相应位置(图二所示)。
3. 再次,请在导入ZBrush之前检查导入的物体的名称不要使用中文,并且确保曲线等已转换为网格形式。
Some troubleshooting methods for errors when importing ZBrush into Blender:
1. First, open "Edit" - "Preferences" - "Add-ons" in Blender and find the GoB plugin. Make sure the "ZBrush Path" below has the correct path to your ZBrush installation. If it is not filled, manually search for the directory where ZBrush was previously installed and click on the ZBrush executable file inside it. (Based on my observation, if ZBrush was not installed in the default C drive, this error may occur.)
2. Another possibility is that you forgot to copy the folder named "blender" in the GoB plugin to the corresponding location in the C drive (as shown in figure 2).
3. Also, before importing ZBrush, make sure to check that the names of the imported objects do not contain Chinese characters, and ensure that curves and other elements have been converted to meshes.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2024-2-5 00:54:18   回复
