[软件问题] 3dmax2023中的复合对象procutter功能是个什么用法?
查看:15940 |回复:3 | 2023-4-4 10:38:22
2023-4-4 10:38:22
3个回答,把该问题分享到群,邀请大神一起回答。
复合对象Procutter功能可以用来对复合对象进行裁剪和分离操作。您可以使用Procutter程序选择需要裁剪的对象,然后使用操作控制器创建裁剪平面来进行裁剪。同时,您还可以使用Procutter功能将裁剪后的对象分离成几个不同的子对象。这个功能非常适用于建模、场景设计和动画制作等领域。
The Procutter feature of Compound Objects in 3ds Max 2023 is used for cutting and separating operations on compound objects. You can use the Procutter program to select the object to be cut, and then create a cutting plane using the operation controller to perform the cutting. At the same time, you can also use the Procutter feature to separate the cut objects into several different sub-objects. This feature is very useful in modeling, scene design, and animation production, etc.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-4-4 10:38:34   回复
2023-5-3 10:26:03   回复
2023-8-30 09:28:28   回复
