[软件问题] max做动画绑定,用“露出变换”吸取“露出节点”后,为什么自动取消已经吸附的节点?...
查看:253 |回复:1 | 2023-6-6 20:57:41
bedf925c151ab351f35a20378acb296.jpg 5742cf86a600f764735e29c86e31835.jpg 请教大神,遇到这种情况问题出在哪里,怎么排查出问题所在?
2023-6-6 20:57:41
1个回答,把该问题分享到群,邀请大神一起回答。
这种情况可能是因为绑定的模型发生了变化,或者节点被意外地移动或删除。您可以尝试重新吸附节点,或者检查模型和节点是否有任何变化,包括角度、位置和名称等。另外,您可以检查max的日志文件来查看是否有任何错误信息。如果问题仍然存在,请尝试使用其他方法进行绑定。
When doing animation binding with Max and using \"Expose Transformation\" to absorb \"Expose Node\", the nodes already absorbed are automatically cancelled. What might be causing this issue, and how can we troubleshoot it?
This situation may occur due to changes in the bound model, or if the node has been accidentally moved or deleted. You can try re-attaching the node, or check for any changes in the model and nodes, including angles, positions, and names. Additionally, you can check Max\'s log file to see if there are any error messages. If the issue persists, try using another method for binding.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-6-6 20:57:55   回复
