[软件问题] maya专家模式快捷键不能用有大佬知道是因为什么嘛。
查看:762 |回复:1 | 2023-6-8 10:54:08
我现在用的Maya2018.6,换成2022也是一样的。或者怎么设置专家模式的快捷方式呢。
参与人数 3元素币 +45 展开 理由
女娲 + 15 【点赞】这很有大网气质!
嫦娥 + 14 【点赞】这很有大网气质!
瑶瑶成神鹿 + 16 【感谢】楼主分享的内容!很棒!
2023-6-8 10:54:08
 赞 赞 9
1个回答,把该问题分享到群,邀请大神一起回答。
你好,可能是因为专家模式下的快捷键需要手动设置才能生效。你可以试试在Maya的主菜单中选择\"Window\" --> \"Settings/Preferences\" --> \"Hotkey Editor\",然后在打开的面板中选择\"Expert Mode\"选项卡,找到你想要设置快捷键的命令,右击选择\"Assign a Hotkey\",然后按下你想要设置的快捷键即可。如果设置成功后还是无法使用快捷键,可能是与你的硬件或软件有关,请尝试升级显卡驱动或重新安装Maya。
Hello, it may be because the hotkeys in expert mode need to be manually set to take effect. You can try selecting \"Window\" --> \"Settings/Preferences\" --> \"Hotkey Editor\" in Maya\'s main menu, then selecting the \"Expert Mode\" tab in the panel that opens, finding the command you want to set a shortcut for, right-clicking and selecting \"Assign a Hotkey\", then pressing the shortcut you want to set. If the shortcut is still not working after successful set-up, it may be related to your hardware or software. Try upgrading your graphics card driver or reinstalling Maya.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-6-8 10:54:23   回复
 赞 赞 2
