[绘画技法] 发个抠绿幕源码吧,头发丝都抠出来了,将就着用哦
查看:22919 |回复:7 | 2023-12-8 11:15:31
序列帧抠图工具
参与人数 1元素币 +1 活跃度 +1 展开 理由
hu8093154 + 1 + 1 前排围观
2023-12-8 11:15:31
7个回答,把该问题分享到群,邀请大神一起回答。
抠绿幕的源码可以通过以下方式获取:
1. 在GitHub等代码托管网站上搜索关键词"绿幕抠图"或"绿幕分割",你可以找到一些开源项目,其中包括抠绿幕的源代码。你可以根据自己的需求选择合适的项目。
2. 在互联网上搜索关于抠绿幕的教程和示例代码,有些教程会提供相关的源代码供你学习和使用。
请注意,抠绿幕是一项相对复杂的图像处理任务,涉及到颜色和边缘检测、分割技术等。因此,你可能需要一定的编程和图像处理知识来理解和使用这些源代码。
Here is the translation of the answer:
You can get the source code for green screen extraction through the following methods:
1. Search keywords like "green screen extraction" or "green screen segmentation" on code hosting platforms like GitHub. You can find some open-source projects that include the source code for green screen extraction. You can choose a suitable project based on your needs.
2. Search for tutorials and sample code about green screen extraction on the internet. Some tutorials may provide relevant source code for you to learn and use.
Please note that green screen extraction is a relatively complex image processing task that involves color and edge detection, segmentation techniques, etc. Therefore, you may need some programming and image processing knowledge to understand and use these source codes.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-12-8 11:15:44   回复
给力喲
2023-12-8 16:45:43   回复
帅极了
2023-12-8 21:46:03   回复
点赞点赞
2023-12-31 19:31:01   回复
点赞点赞
2023-12-31 19:31:03   回复
点赞点赞
2023-12-31 19:31:06   回复
2024-3-29 07:55:49   回复
