Unity3D资源 [其它类型] Adventure Creator Version: 1.65.2 (Oct 24, 2018)
109
6
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 游戏工程 动画|特效 2D资源|工具 其他扩展
File format: unitypackage
Minimum Unity version: 5.6.6
Adventure Creator is the only asset you need to make a traditional 2D, 2.5D or 3D adventure game in Unity - no coding required.
FAQ
Feature list
Video tutorials
Online manual
AC makes game-making a breeze, with its visual scripting system and intuitive Editor controls. Beginners can build an entire game without writing a line of code, while programmers can plug-and-play their own functionality with the documented API.
Created by the author of a commercial title, AC has all the features needed to bring a traditional adventure to market:
● 2D, 2.5D and 3D game modes
● Point and click, direct and FPS movement
● Keyboard, mouse, controller, touch input
● Build to PC, Mac, WebGL, iOS and Android
● NPCs, conversation and interactions
● Inventory, crafting and containers
● Facial expressions and lipsyncing
● Variables to create puzzle logic
● The Room-like physics system
● Completely customisable UI
● Timed sequences and QTEs
● Player-character switching
● Extensive documentation
● Full translation support
● Source code included
● Saving and loading
● Demo source files
AC also integrates with Dialogue System, Cinema Director, Ultimate FPS, 2D Toolkit, PlayMaker, LipSync Pro, SALSA, Slate, RT-Voice PRO and TextMesh Pro! A selection of user-written integrations can also be found on the AC wiki.
PLEASE BACK UP YOUR PROJECT, AND READ THE MANUAL'S "UPDATING ADVENTURE CREATOR" CHAPTER BEFORE UPGRADING.
Version 1.65.2:
= Upgrade note =
-Removed the MainCamera's SetScreenFocus and ReleaseScreenFocus functions, as camera rotation tweaking is now handled by the attached camera
-Added: Tooltips to all Inspector fields (Unity 2017 or later)
-Added: Use of the [paramlabel:X] token for Inventory Item, Global Variable and Local Variable parameters
-Added: Ability to automatically set a Hotspot Interaction ActionList's "Inventory item" parameter to the item used to trigger it
-Added: Custom events triggered when adding and removing Journal pages
-Added: When gathering text, the Speech Manager will now also search Timeline assets for custom Timeline tracks that support translations
-Added: Ability for ArrowPrompts to trigger ActionList assets instead of scene-based Cutscenes
-Added: Minor tweaks to Editor styling in preparation of Unity 2019 theming change
-Added: Warning message to the Console if the "Object: Animate" Action is used to play an animation that doesn't exist using the "Sprites Unity" engine
-Added: Improved default names for Path node cutscenes
-Added: Progress bar to the Speech Manager's "Reset text" operation
-Added: Support for strikethrough, underline, subscript, superscript and link tags when scrolling subtitle text in a TextMeshPro text box
-Added: Ability to ping automatically-set audio and lipsync files from the Speech Manager
-Added: Minor pathfinding optimisations
-Changed: Removed need for a "LookAt transform" child on the MainCamera
-Changed: Removed the MainCamera’s SetScreenFocus and ReleaseScreenFocus functions, as camera rotation tweaking is now handled by the attached camera
-Changed: When head-turning in first person using the "Character: Face object" Action, the pitch and spin rotations are now synchronised
-Changed: The Speech Manager's "Prevent original language from being used?" option has been moved renamed to "Don’t use at runtime?"
-Fixed: ActionList parameter values not restoring correctly upon loading a save file
-Fixed: Hotspots requiring a Highlight component if Hotspot icon display is controlled via script
-Fixed: Cursor icons overlapping in rare circumstances when hovering over inventory items
-Fixed: ActionList node's appearance when using Linear color space in Unity 2017 or later
-Fixed: Cursor error if a Hotspot has an Examine interaction but no Use interaction
-Fixed: "Link graphics to" element property field appearing incorrectly in v1.65.1
-Fixed: Issues when transitioning to and from GameCameras that have a cursor influence
参与人数 1 元素币 +12 活跃度 +24
如果我的资源无效,请在帖子下方留言或通过QQ与我联系(仅限英文)。
双江极品家  发表于 2018-10-25 20:30:01
想要成大触,天天上元素
-関亍牠  发表于 2018-10-29 10:12:21
想要成大触,天天上元素
ふうう  发表于 2018-11-20 19:54:23
谢谢露珠分享~
某一  发表于 2018-11-24 18:00:00
带你赚币带你飞,元素里面有正妹
qq_y7aoyao_U97  发表于 2019-3-4 16:35:26
想要成大触,天天上元素
冬鸦  发表于 2019-3-8 18:04:46
支持一波
slvrsteele 实名
銀色斯蒂爾
201 小时
短杖 学徒法袍 长枪
