骑宠-动物-怪物 [人形怪] 嗜血代码 King 夜魔 夜鬼
1381
7
3D资源
3D资源分类: 低模 次时代
资源题材: 魔幻
美术风格: 日韩 卡通
3D资源格式:
贴图规格与格式:
软件版本要求: 未知或无明确软件版本限制
模型为Toolbag3渲染  模型文件为 OBJ
贴图为 dds 格式  大小为4096x4096
模型有Diffuse  Normal 贴图
带Toolbag3 文件
参与人数 1 活跃度 +15
qq_大脸猫_vUv  发表于 2020-2-23 16:15:27
state stack (ds stack senum>)
The "history" of all state changes. Holds the enum values of each state that has been used since the last time the history was clearec
state_queue (ds queue senum>)
Holds the enum for all states queued up as part of a state queue.
Useful Variables
These variables are provided for you to use, ideally within a state script.
state timer (real.
This variable counts up from O for each step that is spent in the current state. Verv useful for timing thines within al state.
state_new (boolean
This variable is true only for the first step the state is ran, It will also be true the first step after using
truestate reset currenti)
state var (orray <variqusy)
This array can be utilized in a wide variety of ways. Its core purpose is to allow you to keep track of values that wil persist between stens but will only he relevant to the current state and -in some cases- the beginning of the next.
state.
For example, say you have a charge attack that requires the player to hold button down for a set amount of time for different effects. Instead of creating a new "charge hold time" variable, you just use state varf0l, put a comment on it so you know what you are using it for for macro or enum) and then in the next state you can use state varlol fol something else.
It's a bit strange at first, but every time vou go back to your create event to initialize a variable that only one state cares about, ask yourself if you could just use state varll instead.
参与人数 1活跃度 +1
狠人BT + 1 ???
qq_fhd_pce  发表于 2020-2-23 16:39:14
楼主,你是一个大好人!!
傀儡谣  发表于 2020-2-26 11:47:16
huangjiazhoujia  发表于 2020-3-15 13:25:59
楼主,你是一个大好人!!
foruner  发表于 2020-3-21 10:34:23
感谢LZ分享
小毛驴  发表于 2020-3-27 14:35:30
6666666666
ninges  发表于 2023-7-7 03:15:44
庞德哈伦 实名
3 小时
钢剑 长枪 长剑 元素金币 水晶剑 扩散者 六维几何 蓝月药水 英雄盾 元素巨无霸 幻焱之玉 枫月药水 友情药水 白晶石 火元素
