General
Complete name : G:\游戏CG\[4K]《巫师3:狂猎》CG - 难忘惊魂夜.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 861 MiB
Duration : 4 min 45 s
Overall bit rate mode : Variable
Overall bit rate : 25.3 Mb/s
Encoded date : UTC 2021-01-20 02:56:11
Tagged date : UTC 2021-01-20 03:00:04
TIM : 00:00:00:00
TSC : 24
TSZ : 1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference fra : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 25.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.126
Stream size : 850 MiB (99%)
Language : English
Encoded date : UTC 2021-01-20 02:56:12
Tagged date : UTC 2021-01-20 02:56:12
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 4 min 45 s
Bit rate mode : Variable
Bit rate : 317 kb/s
Maximum bit rate : 404 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 10.8 MiB (1%)
Source stream size : 10.8 MiB (1%)
Language : English
