2D动画制作Toonboom Harmony Premium 15.0.5 Build 13929
工具插件软件效率神奇 156 2
发布于 2023-3-7 20:33:30
软件类型: 平面·绘画 动作·捕捉
版本信息: 15.0.5 Build 13929
系统要求: -
官网地址: https://www.toonboom.com/products/harmony
Toon Boom Harmony Premium 15.0.5版是一款十分优秀的2D动画制作工具
价格:30元素币(或3余额) 腾讯微云 销售总额:90元素币 购买人数:3
尊敬的游客 ,本内容需要支付 30元素币十分之一的[余额] 来购买.
What\'s New in Harmony 15: No matter what kind of animation you are working on, you want your production to be at its best. Harmony 15 has new tools that unleash your creativity and improve productivity.
Drawing and Painting: Productivity enhancers speed up the art creation process and new drawing technology in Harmony 15 breaks down the barriers between bitmap and vector.
Access unlimited expression with textured vector brushes that revolutionize art creation. A breakthrough technology, Harmony\'s textured vector brushes, combine the flexibility and speed of the vector workflow with the creativity and raster-level quality of bitmap brushes.
Cut-out Animation: Rigging and cut-out animation production becomes more cost-effective and increases ROI as time goes on. Harmony Premium already gives you the most efficient and flexible tool-set for cut-out projects on the market – whether you need to create something simple or sophisticated. Harmony 15 makes it even easier and faster to go from rigging to animation to final production.
Skillfully handle complex rigs to speed up the animation phase with new Master Controllers. During the rigging phase, write a script for a single controller to animate multiple objects or script as many controllers as you need. Doing turnarounds and other complex animations have never been easier.
New rigging nodes in Harmony 15 empower animators with extended flexibility. Eight nodes have been added including Constraint nodes which use two, three or more points to squash and stretch objects.
Scene Layout and Compositing: Harmony includes an extensive scene layout, animation, compositing and effects tool-set that is unmatched by any other animation package. Harmony 15 builds on this with new features that make it easier for you to create backgrounds and composite effects so the final result is exactly what you envision.
Visualize and build your scenes from A to Z. Expand thumbnails, change drawing exposure durations with handles and adjust the opacity of layers – all within the timeline.
Harmony 15 makes it easier to work in the Node view with larger thumbnail display and a new Mask port on filter and drawing nodes that replaces cutter nodes – simplifying the node tree.
Retina Display Support: With support of Retina and other high resolution displays, the Harmony 15 interface looks sharper and cleaner, making it easier to use. Focused caching improves the performance of scenes that include complex cutout rigs. With the new OpenGL Cache Lock node, you work on one part of a rig without refreshing the cache for the rest -making it faster and easier to animate rigs.
Accelerate Your Art: Ink, paint, rig and animate. Compositing and effects All the tools you need to create your entire project in one tool
Sketch, Draw, and Paint, Bitmap and vector tools for creating art, Create any style with advanced tools that, speed up production, Combine 3D imported, models with 2D for hybrid productions.
Enhance the Look: Create multi-plane scenes using Z-depth, Introduce occlusion and 3D camera moves, Animate in any style, apply effects and composite in 3D.
Harmony 15 has new tools that unleash your creativity and improve productivity !
如果我的资源无效,请在帖子下方留言或通过QQ与我联系(仅限英文)。
元素小王子  发表于 2023-6-4 05:00:45
这个我为什么打了补丁还是解锁不了呢
Hysen  发表于 2024-1-18 21:48:29
补丁下不动
