神级建模插件 Max 2014 RappaTools3
plug-in插件效率神奇工具 317 7
发布于 2023-8-28 18:47:07
3ds Max 2014 RappaTools3 (1444)高级工具箱脚本
版本
英文
max 2014
简介
一个使用高模建模思路,布线自动规范化生成的多边形建模工具集合!
相比当年的ployboost ,有过之,更是有很多 石墨工具 都没有的简单快速的工具
各种指令吓死你!智能强大!
官网
http://remusjuncu.com/rappatools/features.html
下载
或者在 E3D-微元素资源群
107775856 的群共享中
特点
1-把你能用到的所有的建模工具集合在一起!而不是很分散
2-自定义界面,和右键强大的快捷菜单
3-亮点是智能,很多线不用自己连,他会找到规则,帮你工整的连出来
4-ZB的一些雕刻和拖拽样式建模,一种捏模型的感觉
5-捏出来动画效果
6-还有等等自己研究吧!
截图
智能演示
http://player.youku.com/player.php/sid/XNjA3MjAyNzg4/v.swf
安装教程
http://player.youku.com/player.php/sid/XNzE1MTQyNzI0/v.swf
更新记录
ChangelogBuild: 1570 aka 3.31
  • SetID and Select by ID from MaterialID window now works even if you have a modifer selected.
  • Fixed QuadMenu.
  • Fixed ViewportStats bug where it counted tris from objects in a hidden layer.
  • Fixed ViewportStats bug preventing animation from playing.
Build: 1567 aka 3.3
  • Added Viewport Stats.
  • Added to move2grid shift for Align 2 Grid also alt for object pivot center instead of world grid center [0,0,0].
  • Added Inbetween Instances Tool.
  • Added Offset Instances Tool.
  • Added Smooth Loop to Relax.
  • Added Unify Normals Tool.
  • Added Load Material Library into Slate Material Editor.
  • Added local mirror to Mirror X/Y/Z and improved the old mirror features.
  • MiniInterface buttons are now generated based on the 3ds Max UI Colors.
  • Move2Point now uses Transform Gizmo Constraint for axis.
  • Added EPoly Constrains Menu to Sub Object button (rightclick).
  • Added macroscripts for Increment Selection.
  • Added Auto Weld to Quads Extend (SmartQuads).
  • Added Snap to KeyFrames to Time Slider (Shift).
  • Added to MakePlanarXYZ per edge Loop mode as default, ctrl for regular mode.
  • Added support for Elements to RandomSelect.
  • Added Spin on local axis and Zero X,Y,Z roation to RandomFly.
  • Added to Similar select alternate instances select.
  • Added more options for Object ID to Material ID window.
  • Added to NonQuad ctrl for Triangles and shift for faces that have more than 4 sides.
  • Improved Loop / Ring, AutoConnectBridge, Mirror X/Y/Z, WorkingPivot, CenterPivot and Edge RingConnect.
  • Added support for EditPoly to SubObject, Loop, Ring, PlanarLoop, Relax and SmoothingGroups (AutoSmooth).
  • Added support for EditPoly, EditableMesh and Splines to GetSetPointPos.
  • Added support for EditPoly to Chamfer, Extrude, Inset, Cut and TargetWeld from HotBox.
  • Added support for UnwrapUVW to Loop, Ring, Grow Selection, Shrink Selection, GrowLoop, GrowRing and ShrinkLoop.
  • Added Set Object Height Ratio that will scale the length and width so it maintains the size ratio.
  • Added Drag, Extend, Optimize, StepBuild, Topology and Strips to quickTopo.
  • Fixed bugs, code cleanup (6k+ lines removed) and rewrites.
  • ! Removed Noise Tool and Smooth Tool.
Build: 1515 aka 3.2
  • Added quickTopo for quick retopology.
  • Added WorkingPivot Tool.
  • Added Weld 2 Last, Move 2 Grid, Drop on Grid and Move On Grid.
  • Added Smart Transform Toggles where you double tap to change the coordinate sys.
  • Added ActiveGrid like the WorkPlane inside Modo.
  • Added the ability to customise the HotBox.
  • Added planarLoop for X and Z to GetSetPointPos.
  • Improved the Slide (also now the +ctrl is for sliding partial loops).
  • Improved SmartQuads, also added Quads Extend.
  • Improved AutoConnectBridge, it can be used to quad cap much faster now.
  • Improved ChamferOp, also added parallel and flat quad chamfer modes.
  • Improved Mirror X Y Z, also added new options.
  • Improved CenterPivot to work with subObjSelection for splines, EditPoly and EditablePoly/Mesh.
  • Improved Set Object Scale and Set Object Height to work with multiple objects selected.
  • Improved the Materials, now they are reused instead of making new ones.
  • Improved ExpertMode, also added UVW Edit Mode and ToggleEdgeSelected.
  • You can double tap the SubLevelShortcuts to return to level 0 if keyboardShortcutOverwrite off.
  • If you quickly double tap toggleEndResult it will toggle Show Cage.
  • Various Fixes, Changes and Improvements...
Build: 1444 aka 3.1
  • Added: Auto Connect Bridge.
  • Added: SmartQuads.
  • Various interface changes.
  • Usability and Speed improvements.
  • Minor fixes and 3ds max 2014 support.
Build: 1425
  • Changed install path to userscripts.
  • Speed improvements.
  • IsolationMode now hides helpers.
  • Added TimeSlider tool, see ViewportTools or macros.
Build:1406
  • New interface.
  • New dialogs.
  • Added gridDeform.
  • Added Align/Scale/Rotate that contains \'Move to Point\', \'Points Aling\', \'Set Object Scale\', \'Set Object Height\'and \'Rotate Around Point\'.
  • Added Brushes (standard, move, smudge, inflate, pinch, relax, noise).
  • Added to Similar select instances if SubObjectLevel = 0.
  • Added Silhouette View. (::RappaTools3.SilhouetteView())
  • Added \'SplineRefine\' to Verts Tool.
  • Spline Bridge update.
Build:1358
  • ChamferOp with \"Uniform Mitering\", QuadChamfer and UnChamfer.
  • More MacroScripts...
  • RightClick menu to +Save and Adjacent.
  • Isolation Mode.
  • Improved GeoPolygon the outline feature.
  • QuadMenu.
那时候的你  发表于 2021-4-21 22:25:15
针不错
DawnSky  发表于 2021-4-22 08:49:35
看着有点像maya
超级下下  发表于 2021-9-23 16:21:37
清明樱花祭  发表于 2021-11-27 19:35:07
qq_蜗牛_usI  发表于 2022-7-21 09:33:22
艾恩斯  发表于 2023-5-3 10:16:32
石小墩呀  发表于 2023-6-15 09:07:27
学习学习
