经典建模工具Houdini插件 Modeler V1.0.4版
效率神奇工具 89 0
发布于 2022-8-31 18:17:30
插件类型: 其它软件的插件
版本信息: V1.0.4版
软件版本要求: Houdini 18
官网地址: -
Modeler经典建模工具Houdini插件V1.0.4版
价格:26 元素币 百度网盘 收益:0元素币 销量:0
尊敬的游客 ,本内容需要支付后可见.
提醒使用【余额支付】需要: ¥2 余额
大小:290 MB,支持Houdini 18版软件,支持Win系统,语言:英语.
1. Edit Mesh state Edit Mesh is a standalone modeling environment, which allows you to use classic mesh modeling tools. You can quickly create models, UV maps and retopologize high-poly mesh just like in other modelers.
2. Soft Boolean Soft Boolean can create procedural models using boolean operations, but unlike the standard Boolean SOP, it creates soft transitions between cutter and main geometry.
3. KitBash The KitBash Python panel allows to catalog geometric data without saving them in separate files. KitBash can create subfolders and use models in the form of simple thumbnails.
4. Insert Mesh Insert Mesh is a HDA node that allows embed parts of geometry in any place using selected polygons. You can use this node in the Network Editor as usual, but the main feature is using it in conjunction with the KitBash Python panel. That means you can create your own sets of geometry parts in KitBash and insert them later in your model with Insert Mesh technology.
5. Zone Menus Thanks to Qt and PySide libraries Modeler has its own marking menu system called Zone Menus. You can create very customizable menus using a simple Python syntax. Zone Menus can contain submenus and gestures. Gestures allow to call often used tools as fast as possible.
