Unity3D资源 [功能/工具] Vertex Tools Pro-功能丰富的顶点绘画编辑器
157
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 其他扩展
价格:150元素币(或15余额) 百度网盘 销售总额:300元素币 购买人数:2
尊敬的游客 ,本内容需要支付 150元素币十分之一的[余额] 来购买.
Vertex Tools Pro Editor Extensions/Painting
Monoment
This extension requires one license per sea
Requires Unity 5.4.3 or higher.
Vertex Tools Pro is a feature packed editor extension optimized for the physical rendering pipeline of Unity 5. It lets you blend different PBR materials based on heightmaps and different options to play with. We aimed to create a workflow that is at the same time as artist friendly as possible and still ensures high performance realtime rendering. Vertex Tools Pro comes with a fully functional Vertex Painter, a Vertex Deformer, Vertex Color Animator and Flowmapping as well as with a couple of PBR-Shaders especially created for this tool.
The demoscene from the screenshots is available as a standalone demo:
Features
Vertex Painting:
• Easily paint your meshes
• Optimized workflow for rapid progress
• Multi-Object Editing for seamless transitions between gameobjects
• Integrates well with the complimentary shaders
• All Painted meshes can still be static, except when using our runtime API to paint ingame of course
SpeedTree Painting:
• Easily paint your SpeedTrees
• Add translucency to the leaves to instantly make your environment way more lively
• Paint the branches with our heighbased-blending
• Use tessallation on the branches to better integrate the trees in the environment
Shader
• Fully PBR Shaders
• Blend upto 3 fully PBR Materials
• Simply paint wetness onto your models
• Simply paint UV Flow with your mouse to let your materials flow like you want them to
• Optional Parallax (POM) Mapping with Depth-Bias
• Optional Heightbased Blending & Heightbased Transparency Support
• Adjustable Edge Smooth when using Heightbased Blending
• Transparency Shader - Reflective / Refractive with optional blur
• Tessellation Shader - Get ready for the next-gen and make use of our custom Tessellation shader which brings AAA quality to your project
• Mobile Shader - Vertex Tools Pro comes with shaders that are targeted for Shader Model 2.0 and therefore for your mobile or webgl project
Mesh Deforming
• Manipulate your Meshes on the fly
• Intrude/Extrude, push/pull or pinch Vertices
• Smooth hard edges
FlowMapping
• Simply Paint Flow on the mesh with your mouse. You define direction and speed.
• Make the complimentary shaders flow
• Bake FlowMap Data into Vertex Data
• Generate FlowData based on Mesh geometry
Runtime API
• Make use of our Runtime API
• Paint meshes on-the-fly, ingame, in realtime
• Deform meshes on-the-fly, ingame, in realtime
Texture Assistent
Our shaders are highly optimized for performance. For that we supply you with our Texture Assistant to easily pack textures.
HyuJung 实名
6080 小时
裁决 彗星钛晶矿 阿尔法晶矿 水晶剑 元素之铠 元素之盾 紫色药水 短杖 学徒法袍 无色原始矿 绿母翠晶矿 钢铁矿镐 元素银币 元素金币 长剑 铁剑 长枪 火元素 宏观物质 翡翠剑
