Unity3D资源 [模型/材质] 最新的Shader Forge v1.2.5
345
3
引擎插件类型
软件版本要求: unity4.5.0
引擎插件类型: 材质|Shader
【名称版本】Shader Forge 1.25
【官方链接】https://www.assetstore.unity3d.com/#/content/14147
【宝贝描述】Requires Unity 5.1.0 or higher.
Shader Forge v1.25
Links: Website | Forum thread | Nodes| FAQ
简体字 | 正體字
Note: Unity 4 support dropped after v1.06
Shader Forge is a node-based shader editor, aiming to push the visual quality of Unity to new heights, giving you the artistic freedom of shader creation in a visual and intuitive way - no code required!
What am I buying?
• Commercial license of Shader Forge + upcoming updates
• A pack of example shaders to study and use freely
Workflow:
• Create shaders visually, without any coding needed
• No extra files to sync over your version control system; Shader Forge uses a single file for shaders - the .shader file itself
• SF writes CG shaders that can be used in any project, without installing Shader Forge
• Works in both Unity Pro and Unity Free
• Documentation and support center, for contributing feedback and bug reports
Some of the features:
• Built-in Physically Based Lighting mode and energy conserving shading
• Visual and intuitive interface - Get a clear overview of what each node does
• Custom lighting nodes and IBL support
• DX11 Tessellation & Displacement
• Transparency; both partial and alpha clipping
• Refraction & Render Textures
• Optionally use lightmapping and light probes / Spherical harmonics
• Plus all the essentials such as cubemaps, custom blending modes, depth sorting, fog control, and much much more!
Alpha/Beta tests so far:
Shader Forge has been alpha-tested by a wide range of developers at companies ranging from several large studios such as Valve, Blizzard, DICE, Ubisoft, Bungie, EA, Avalanche Studios, Rovio, to indie studios such as Killbrite, InXile, The Chinese Room, and even developers like Marmoset, Samsung and Unity themselves.
pangqianwei  发表于 2023-6-7 15:38:39
镇魂曲  发表于 2024-3-11 16:21:24
1111111111111111111
越狱兔  发表于 2024-7-30 15:32:12
落落乖 实名
1885 小时
【绝】结界玄晶 神界之石 裁决 神速靴 火元素 微库VIP 小苹果 大菠萝 元素铜币 元素银币 元素金币 元素秘币 元素圣币 长剑 长枪
