Unity3D资源 [功能/工具] [unity插件]Alloy Physical Shader Framework 超牛着色框架-3.2.7版本(百度网盘)
202
引擎插件类型
软件版本要求: 要求Unity 5.0.1或更高版本
引擎插件类型: 材质|Shader 后处理
资源包名:Alloy Physical Shader Framework超级牛逼shader框架.行业大牛推荐.YOUTUBE作者视频已上传.回复可见发布者:RUST LTD价格:$125适用版本:要求Unity 5.0.1或更高版本。文件大小:510K资源有问题.或者链接不存在.请私信.或者Q群小窗.看到立马解决Asset store 链接:https://www.assetstore.unity3d.com/en/#!/content/11978
链接:http://pan.baidu.com/s/1mifDkM0 密码:ym1v
Version 3.3 Now including Deferred Character, Transmission, Decal, and SpeedTree ShadersAlloy Physical Shader Framework 3 is the most powerful, extensible, and complete set of physically-based shaders for Unity 5. Designed for the optimal balance of feature set, clean workflow, and flexibility, Alloy is ready to help you hit that \'AAA\' feel.Sample Assets can now be found here: ALLOY SAMPLESClick for more info. | Forum ThreadRebuilt from the ground-up for Unity 5, Alloy 3 expands the variant-count from dozens to hundreds of thousands. With our new custom inspector, you can seamlessly add and remove features you need with a single click.Togglable Shader Property Groups:- Parallax/POM- AO2- Detail Mapping- Decal Mapping- TeamColor Mask- Emission- Rim Emission- VFX DissolveShaders Include:- Core- 4-Splat Terrain- Pre-Integrated Skin- Parallax Eye- Anisotropic Hair - Deferred-Compatible Carpaint- Refractive Glass - Oriented Blend- Weighted Blend- SSS Transmission- VFX Transition- Full Particle Shader Set- With variants as needed of each!
成林 实名
unity3D
5805 小时
【绝】结界玄晶 微库VIP 扩散者 紫色药水 学徒法袍 元素铜币 元素银币 元素金币 元素秘币 长剑 绿色药水 长枪 火元素
