【A站自购】HairTG-Cards-Indie Pro, commercial-程序化生成头发模型与纹理-专业版本...
面片插片效率神奇工具 928 28
发布于 2023-4-27 13:02:42
价格:2000元素币(或200余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 2000元素币十分之一的[余额] 来购买.
做头发的神器,本版本是 160 美元 购买的,是拥有全套核心文件和教程的版本  Pro, commercial
此资源为Por版本,价格偏贵,也可先购买试用版本玩玩看点击跳转
HairTG-Cards re-imagines hair card authoring with compelling and 100% procedural texturing and modeling tools within Substance 3D hosts.
Create hair textures directly in Substance 3D Painter from the many available design presets. Modify hair texture properties in real time in Painter and see the result in-context, on the hair model within your 3D scene.
HairTG-Cards also enables to create hair card based 3D hair models within Substance 3D Stager using procedural geometry generation tools.
A Discord server is available for questions and support!
Requirements
Substance 3D Painter 7.4 / 2021 or compatible version for texturing, Substance 3D Stager 1.1.2 or compatible version for modeling.
The modeling and texturing tools are independent. It is also possible to use the modeling tools partially and complete the model into another software.
Main features
Texturing in Substance 3D Painter
  • Procedural PBR hair/fur texture generation for hair cards in Substance 3D Painter with direct visualization on the 3D model.
  • Modular design and centralized control: design hair textures independently and control their main properties from a centralized Controller enabling to change various properties to all the hair textures at once such as thickness, length, waving etc. all this with direct visualization on the 3D hair model within Painter.
  • Supported PBR maps: Opacity, ID, Depth (Height/Displacement), Color, Flow (Direction), Anisotropy Angle and Level, Normal, Ambient Occlusion, Roughness, Root and Tip.
  • Dozens of artist-designed texture presets ready to be used and modified through parameters.
  • Many parameters to procedurally generate hair textures including hair thickness, length, shape, density, waving, per-hair opacity handling, combing, layering, multiple hair grouping levels, clumping, braid/rope designs and many more.
  • Automated variation support enabling to obtain hundreds of unique designs by just moving a slider.
  • Extensive coloring modes including shadowing modes, tint modes in full and at root/tip, color presets, automatic color palettes and Blend Maps.
  • Morphing support enabling to morph a design into one another, also usable to generate variations.
Modeling in Substance 3D Stager
  • Procedural hair card 3D model generation in supporting .sbsm Substance 3D Model hosts (Substance 3D Stager).
  • Enables generation of complex hair/fur models using a modular approach. Generates groups of cards with independent properties which, when assembled, produce a complete hair or fur model.
  • Multiple card distribution options with two types of configurable virtual supports.
  • Variation parameters enabling to quickly generate alternate variations of the models.
  • Smart mirroring enabling to lay out cards on both sides of the head simultaneously, varying the distributions so they do not look similar.
  • Multiple card shaping capabilities such as multi-location directional bending, twist, spiral.
  • Ability to distort cards along their width.
  • Selectable number of geometry subdivisions along the card’s width and length.
  • UV assignment per card type.
  • Several card types per card group, each to be UVed independently.
Pro components for Substance 3D Designer (HairTG-Cards Pro only)
  • Export design data from Painter and use them in Designer to create materials covering multiple designs, controlling all textures of a full hair model in any supporting Substance 3D host (such as Stager).
  • Create custom design presets and Morph Shapes in Designer.
  • Create your own texture graphs in Designer with the ability to control multiple textures at once from a Controller node.
Editions
  • HairTG-Cards Mini (Personal): this is a try-out, non-commercial edition, with limitations such as texture resolution at 512x512, texturing tools only (no modeling) with a selection of parameters. However this is a great edition to start with, you'll see how things work overall and can even make pretty cool hair with it! It comes with a dedicated tutorial video. HairTG-Cards Mini is included in the regular and Pro editions.
  • HairTG-Cards (Personal/Indie): the regular HairTG-Cards edition contains the full texturing and modeling tools for Substance 3D Painter and Stager, 40 artist-designed texture presets, each of them with at least 2 morph shapes and hundreds of possible random variations, global control over multiple textures within a texture set etc.
  • HairTG-Cards Pro (Indie/Studio): same content as the regular edition plus Substance 3D Designer specific content. This edition enables to export texture design data from Painter and use them in Designer to make hair/fur materials covering whole texture sets, which can then be used into other Substance 3D hosts such as Stager. Also contains several components for Designer to make hair texture graphs and Morph Shapes.
Contents
HairTG-Cards Mini:
  • SBSARs for Substance 3D Painter.
  • Tutorial video.
HairTG-Cards Mini is also  included in the regular and Pro editions below, you may use it to learn the basis of the tool if you prefer as it is simpler and has a dedicated tutorial. You may also start directly with the regular HairTG-Cards tutorial, it's up to you!
HairTG-Cards:
  • SBSARs for Substance 3D Painter and SBSMs for Substance 3D Stager.
  • 6 manuals: Texturing/Modeling manuals and Reference manuals.
  • Tutorial videos (about 4h in total).
HairTG-Cards Pro:
  • Same content as the regular HairTG-Cards edition.
  • SBS files for various components except the hair generators which are SBSAR only. Specific tutorial videos.
License notice
Licenses are single seat only. You cannot resell or distribute the package or some of its content into a form that would expose it to reuse. In particular you cannot share Painter projets or Smart Materials made using SBSARs from this package unless users have an appropriate license of this product.
License types
  • HairTG-Cards Mini, non-commercial: for personal use (not companies), the product may be used for non-commercial projects only.
  • HairTG-Cards Personal, non-commercial: for personal use (not companies), the product may be used for non-commercial projects only.
  • HairTG-Cards Indie, commercial: the tool and generated textures may be used for commercial projects, for individuals, schools or companies with revenue below USD $100K a year.
  • HairTG-Cards Pro Indie, commercial: the tool and generated textures may be used for commercial projects, for individuals, schools or companies with revenue below USD $100K a year.
  • HairTG-Cards Pro Studio, commercial: the tool and generated textures may be used for commercial projects, for individuals, schools or companies with revenue above USD $100K a year.
Release Notes
HairTG-Cards Mini was added to all the editions, this is a great way to learn the tool if you prefer as it is simpler and has a dedicated tutorial. Besides this the components haven't changed.
HairTG-Cards 在 Substance 3D 主机中使用引人注目的 100% 程序纹理和建模工具重新构想发卡创作。
从许多可用的设计预设中直接在 Substance 3D Painter 中创建头发纹理。在 Painter 中实时修改头发纹理属性,并在 3D 场景中的头发模型上在上下文中查看结果。
HairTG-Cards 还可以使用程序几何生成工具在 Substance 3D Stager 中创建基于发卡的 3D 头发模型。
Discord 服务器 可用于问题和支持!
要求
Substance 3D Painter 7.4 / 2021 或用于纹理的兼容版本,Substance 3D Stager 1.1.2 或用于建模的兼容版本。
建模和纹理工具是独立的。也可以部分使用建模工具并将模型完成到另一个软件中。
主要特点
Substance 3D Painter 中的纹理
  • 在 Substance 3D Painter 中为发卡生成程序 PBR 头发/毛皮纹理,并在 3D 模型上直接可视化。
  • 模块化设计和集中控制:独立设计头发纹理并从中央控制器控制它们的主要属性,从而可以一次将各种属性更改为所有头发纹理,例如厚度、长度、波浪等。所有这些都可以在 3D 头发模型上直接可视化在画家中。
  • 支持的 PBR 贴图:不透明度、ID、深度(高度/位移)、颜色、流动(方向)、各向异性角度和水平、法线、环境光遮挡、粗糙度、根和尖端。
  • 数十个艺术家设计的纹理预设可供使用和通过参数进行修改。
  • 程序化生成头发纹理的许多参数,包括头发厚度、长度、形状、密度、波浪、每根头发的不透明度处理、梳理、分层、多个头发分组级别、结块、编织/绳索设计等等。
  • 自动变化支持,只需移动滑块即可获得数百种独特的设计。
  • 广泛的着色模式,包括阴影模式、完全和根部/尖端的着色模式、颜色预设、自动调色板和混合贴图。
  • 变形支持使设计能够相互变形,也可用于生成变化。
在 Substance 3D Stager 中建模
  • 支持 .sbsm Substance 3D 模型主机(Substance 3D Stager)中的程序发卡 3D 模型生成。
  • 支持使用模块化方法生成复杂的头发/毛皮模型。生成具有独立属性的卡片组,这些卡片在组装时会生成完整的头发或毛皮模型。
  • 具有两种可配置虚拟支持的多种卡分配选项。
  • 能够快速生成模型的替代变体的变体参数。
  • 智能镜像能够同时在头部两侧布置卡片,改变分布,使它们看起来不相似。
  • 多种卡片整形能力,如多位置定向弯曲、扭曲、螺旋。
  • 能够沿宽度扭曲卡片。
  • 沿卡片宽度和长度的可选几何细分数。
  • 每种卡片类型的 UV 分配。
  • 每个卡片组有几种卡片类型,每种卡片都可以独立进行 UV 处理。
Substance 3D Designer 的 Pro 组件(仅限 HairTG-Cards Pro)
  • 从 Painter 导出设计数据并在 Designer 中使用它们来创建涵盖多个设计的材质,控制任何支持 Substance 3D 主机(例如 Stager)中完整头发模型的所有纹理。
  • 在 Designer 中创建自定义设计预设和变形形状。
  • 在 Designer 中创建您自己的纹理图,并能够从控制器节点一次控制多个纹理。
版本
  • HairTG-Cards Mini  (Personal):这是一个试用版,非商业版,有一些限制,例如纹理分辨率为 512x512,只有纹理工具(无建模)和参数选择。然而,这是一个很好的开始版本,你会看到整体是如何运作的,甚至可以用它做出很酷的头发!它带有专门的教程视频。HairTG-Cards Mini 包含在普通版和专业版中。
  • HairTG-Cards(个人/独立):常规的 HairTG-Cards 版本包含 Substance 3D Painter 和 Stager 的完整纹理和建模工具,40 个艺术家设计的纹理预设,每个预设至少有 2 种变形形状和数百种可能的随机变化,对纹理集中多个纹理的全局控制等。
  • HairTG-Cards Pro(独立/工作室):与普通版相同的内容加上 Substance 3D Designer 特定内容。此版本支持从 Painter 导出纹理设计数据,并在 Designer 中使用它们来制作覆盖整个纹理集的头发/毛发材料,然后可以将其用于其他 Substance 3D 主机,例如 Stager。还包含几个组件供设计师制作头发纹理图和变形形状。
内容
HairTG-卡迷你:
  • Substance 3D Painter 的 SBSAR。
  • 教程视频。
HairTG-Cards Mini 也包含在下面的普通版和专业版中,如果您愿意,可以使用它来学习该工具的基础,因为它更简单并且有专门的教程。您也可以直接从常规的 HairTG-Cards 教程开始,这取决于您!
HairTG-卡:
  • 用于 Substance 3D Painter 的 SBSAR 和用于 Substance 3D Stager 的 SBSM。
  • 6 手册:纹理/建模手册和参考手册。
  • 教程视频(总共约 4 小时)。
HairTG-Cards Pro :
  • 与常规 HairTG-Cards 版本相同的内容。
  • 用于各种组件的 SBS 文件,但头发生成器仅是 SBSAR。具体教程视频。
许可通知
许可证仅限单座。您不能将包裹或其部分内容转售或分发到可以重复使用的形式中。特别是,除非用户拥有此产品的适当许可,否则您不能共享使用此软件包中的 SBSAR 制作的 Painter 项目或智能材料。
许可证类型
  • HairTG-Cards Mini,非商业:供个人使用(非公司),该产品只能用于非商业项目。
  • HairTG-Cards  Personal, non-commercial : 供个人使用(非公司),该产品只能用于非商业项目。
  • HairTG-Cards  Indie,商业:该工具和生成的纹理可用于商业项目,适用于年收入低于 10 万美元的个人、学校或公司。
  • HairTG-Cards Pro  Indie,商业:该工具和生成的纹理可用于商业项目,适用于年收入低于 10 万美元的个人、学校或公司。
  • HairTG-Cards  Pro Studio,商业:该工具和生成的纹理可用于商业项目,适用于年收入超过 10 万美元的个人、学校或公司。
发行说明
HairTG-Cards Mini 已添加到所有版本中,如果您愿意,这是学习该工具的好方法,因为它更简单并且有专门的教程。除此之外,组件没有改变。
参与人数 10元素币 +110 活跃度 +67 展开 理由
大西几 + 13 + 4 资源甚好,发帖艰辛,且阅且珍惜。
wstracy + 7 + 4 这就是大佬的世界嘛
aiko33 + 5 + 8 看起来不错
KKAAdx332 + 13 + 10 支持一下
Ap1600 + 8 + 10 【给力】阅贴无数,楼主最强!
淼煮鱼 + 5 + 9 强啊
lilik60038 + 16 + 3 每天一早上元素,挖矿撩妹两不误。
羊杂OL + 20 + 8 原创作品发元素,日积月累成大触。
kiwi + 15 + 8 资源甚好,发帖艰辛,且阅且珍惜。
mome + 8 + 3 【喜欢】看到这么好的帖如同回到初恋的年代!
许多人想登上月球,而我却想多看看树。
回忆、谁黯伤  发表于 2022-4-25 10:16:26
esll7  发表于 2022-4-25 11:09:40
元素界王神  发表于 2022-4-25 14:18:07
老贵了 是个好东西
Zh_Jason  发表于 2022-4-25 14:23:37
是要从新购买HairTG-Cards Pro  Indie专业版吗
回复
专业版的话要重新购买  发表于 2022-4-26 14:09
近视的鱼  发表于 2022-4-25 18:45:58
这次来看看东西好不好
随浪逐波  发表于 2022-4-26 15:07:19
wangzhenmo  发表于 2022-4-26 15:45:41
6666666
争分  发表于 2022-4-27 17:43:23
漫道  发表于 2022-4-29 09:09:57
《-至尊宝-》  发表于 2022-5-1 01:51:30
呆头蚁  发表于 2022-5-7 16:47:41
20#
12下一页
