C4D真实波浪模拟插件 HOT4D for Cinema 4D R25-R26
116 0
发布于 2023-3-1 09:11:06
价格:1元素币(或1余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 1元素币十分之一的[余额] 来购买.
HOT4D可以在C4D中轻松模拟制作海面波浪效果,基于α透明通道来制作波浪起伏效果。
HOT4D allow you to create Ocean that look real.HOT means Houdini Ocean Toolkit. It’s a plugin for Houdini created by Drew Whitehouse based on a Jerry Tessendorf paper.It allow you to create a surface that look like a deep ocean.
支持的软件版本:
  • Cinema 4D R25-R26
安装步骤:
  • 将hot4d文件夹拷贝到C4D安装目录的plugins即可
  • Scale your volumetric rendering
    Designed to process and render millions and even billions of particles, AWS Thinkbox Krakatoa provides a pipeline for acquiring, caching, transforming, modifying, shading, and rendering vast quantities of particles. Krakatoa helps artists render natural phenomena like dust, smoke, ocean foam, viscous liquids, and even solid objects to production quality standard. Krakatoa has been used in-production to generate visual effects and elements for movies like Avatar, Harry Potter And The Deathly Hallows 2, The Avengers and Star Trek: Into Darkness.
签名被屏蔽
