C4D Redshift渲染器使用PBR材质结构插件 R20-R25 Win/Mac + 使用教程
118 0
发布于 2023-3-5 20:16:08
价格:1元素币(或1余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 1元素币十分之一的[余额] 来购买.
C4D Redshift渲染器使用PBR材质结构插件 Redshift PBR Material V1.0 For Cinema 4D R20-R25 Win/Mac + 使用教程
此插件可以一键创建具有 PBR 结构的整洁且易于使用的 Redshift 材质。
This plugin will create a tidy and easy-to-use Redshift material with a PBR structure in just 1 click.Depending on how many texture maps you need to use, the creation of a friendly node system with everything plugged and working nicely can be tiring and time consuming. And this problem is even worse when you need to create lots of different materials based on several PBR textures to be used without UV map. In that case you’ll need TriPlanar node for every texture on every material, and probably a Ramp or Color Correct node to control the behavior of each texture, plus a rig to remap all of them.
插件要求:
  • Redshift  3.0.16或者更高版本
  • Cinema 4D R20或者更高版本
安装步骤:
  • 拷贝Redshift PBR Material v1.0到C4D安装目录的plugins即可
  • This plugin allows a seamless background & floor for Redshift in Cinema 4D. This is extremely helpful for product renderings & it is very easy to use. You can also catch the shadow & reflection as well as control the reflectivity & the color of the background.
签名被屏蔽
