C4D弹性动画模拟插件 Orestiskon Springy Fro Cinema 4D R20-R25 + 使用教程...
106 0
发布于 2023-3-7 11:46:28
可以在C4D中给模型添加弹性动画,可以用于关键帧或者表达式驱动的动画上Springy adds non-destructive overlap to animated objects.
  • Objects with keyframes
  • Objects without keyframes (e.g. children of animated objects)
  • Objects driven by expressions
支持的软件版本:
  • C4D R20/R21/R22/R23/R24/R25
安装步骤:
  • 将Springy 文件夹拷贝到C4D插件文件夹下即可
  • The Auto-Overlap Tool
    • Easy to UseApply it to multiple animated objects and Springy will automatically add overlap on their motion.
    • Non-DestructiveSpringy works procedurally and the original animation can be edited on the fly. It can also be applied to objects without keyframes or driven by expressions.
    • DirectableControl the overlap with separate Position and Rotation control,  exclude individual channels and fade it with Per Object Strength falloff.Multiple Springy Objects can be used simultaneously or even layered together on the same objects.
    • AdaptableSpringy has parameters to fit different use-cases. In this example, there are long hierarchical chains which cause a very strong Cumulative effect, in which case it can be turned off.Other options include Spring or Smooth modes and Global or Local space.
签名被屏蔽
