C4D样条线缠绕插件 C4DZone Spline Wrapper v3.0 For Cinema 4D R21-R25破解版+使......
122 0
发布于 2023-3-7 22:13:51
C4D样条线缠绕插件 C4DZone Spline Wrapper v3.0 For Cinema 4D R21-R25破解版+使用教程
Spline Wrapper是一款可以作用于样条线上的插件,模拟各种复杂的缠绕效果
  • Spline Wrapper is a plugin dedicated to spline objects. With this tool you can quickly make some impressive special effects. Wrapping your objects with spline could not be very easier than this.
  • Spline Wrapper creates paths around or inside your objects, gives user the power to make special effects with Sweep Nurbs around objects, crosslinked,veins, nets and much more. You can wrap logos, objects, characters or whatever you want in a few seconds.
  • Spline Wrapper easily handles the number of coils around object, precision, random factor, quality and other simple parameters.
支持的软件版本:
  • C4D R21/R22/R23/R24/R25
安装步骤:
  • 将splinewrapper文件夹拷贝到C4D插件文件夹下
  • 打开C4D,Plugin插件目录下选择SplineWrapper_KG.pypv弹出许可文件生成窗口,点击Generate youe license,弹出序列号窗口,右键复制序列号
  • Plugin插件目录下选择Reload Python Plugin弹出插件注册窗口,粘贴序列号,点击Activate youe license,就可以激活插件了
  • 重启C4D,就可以看到splinewrapper插件了
签名被屏蔽
