C4D多边形纹理随机生成插件 PolyDivider V1.07 for Cinema 4D R20-R25 破解版 + 使......
153 0
发布于 2023-3-8 19:47:31
C4D多边形纹理随机生成插件 PolyDivider V1.07 for Cinema 4D R20-R25 Win破解版 + 使用教程
PolyDivider是一款基于矩形生成多个随机机型纹理图形的C4D插件,对生成图形纹理可以另外进行多种效果器的控制
PolyDivider is a Cinema 4D Deformer plugin that makes polygon subdivisions with procedural algorithm designed to produce random geometric patterns based on a rectangle. The idea came from the type of diagrams called “treemaps”, that takes a rectangle and splits it vertically and then horizontally.
支持的软件版本:
  • Win,Cinema 4D R20/R21/R22/R23/R24/R25
安装步骤:
  • 拷贝PolyDivider文件夹到C4D安装目录的plugins里面
The outcome is fed to the loop, again and again, depending on the number of user-defined iterations. A seed value and slight alterations of the algorithm produce a variety of results.Requirements
PolyDivider required Cinema 4D R20 and higher, Win/Mac
Current Known Limitations
  • Plugin interprets N-gons like subdivided polygons
  • Extrude Inner function do not working with non planar polygons
  • Interface
    Plugin designed as object deformator.
签名被屏蔽
