3DS MAX场景模型导入C4D插件 MAXtoC4D v6.0 R15-R25 Win破解版
101 1
发布于 2023-4-21 20:42:14
插件类型: C4D
版本信息: v6.0
软件版本要求: R15-R25
官网地址: https://www.3dtoall.com/products/maxtoc4d/
MAXtoC4D可以将3Ds MAX模型完全导入C4D中,操作十分简单,支持兼容Vray / Corona / Octane / Redshift等多种渲染器
MAXtoC4D:将3DS MAX模型转换后导入到C4D中
  • MaxToC4D is a plugin to transfer 3DsMax current scene to C4D with 2 clicks, solving common problems between import/export problems automatically, to get the best results in the fastest way and with the less effort possible.
支持的软件版本:
  • 3DS MAX 2014 – 2022
  • Cinema4D R15 – R25
安装步骤:
MaxToC4D:
  • 安装MaxToC4D_6_Setup.msi
  • 打开C4D,在顶部菜单,扩展-用户脚本-运行脚本,弹窗里拾取Keygen文件夹里面的3DToAll_C4D_Master_Keygen.py
  • 点击Generate就可以得到IKMAX、Max To Cinema4D、Cinema4D To Max这3个插件的序列号,复制你需要的序列号
  • 在扩展打开对应的插件,粘贴对应的序列号,然后SUBMIT即可
MaxToC4D v6.3
From 3ds Max to Cinema 4D with '2 clicks'.
  • Vray, Corona, Octane, Redshift Support!
  • Expand your Cinema 4D library of objects!
  • Open models made for 3ds Max and send them to Cinema 4D with '2 clicks'
  • Use the powerful 3ds Max tools and transfer the scene to Cinema 4D
  • And much more!
Supports: 3ds Max 2015-2023 Cinema 4D R17-S26
What is MaxToC4D?
MaxToC4D is a plugin to transfer 3ds Max current scene to Cinema 4D with 2 clicks, solving common problems between import/export problems automatically, to get the best results in the fastest way and with the less effort possible.
Who is this for?
For all 3D artists using 3ds Max and/or Cinema 4D. You will get instant benefits.
If you are a 3ds Max user you can add a new dimension to your workflow sending your scenes to Cinema 4D to use the fast advanced render there, or the library of objects, or the amazing hair/grass integrated system, etc
If you are a Cinema 4D you can sometimes prefer to model inside 3ds Max for specific tools, or because you have models already done there, or because you have purchased some models in the past in .max format (arch models etc) and you want them inside a current Cinema 4D project in a fast way.
签名被屏蔽
a@南か柯  发表于 2022-7-4 14:19:39
666正好需要
