C4D模型放置任意表面位置插件 Target4D v1.5.9 For Cinema 4D + 使用教程...
122 1
发布于 2023-4-22 09:04:37
Target4D可以将模型放在另外一个模型表面的任意位置
Target 4D is a Cinema 4D R14 and higher plug-in designed to move or copy selected objects onto the geometry surface of other scene objects. This tool is absolutely suitable for interior and exterior architectural use and will save you a lot of time!
支持的软件版本:
  • Cinema 4D R17或者更高版本
安装步骤:
  • 拷贝Target4D文件夹到C4D安装目录的plugins即可
Features
  • Place or copy objects onto any surface.
  • Quickly switch between active objects using hot keys.
  • Use advanced copy modes: random, along the line, by the grid.
  • Interactive interface for quickly changing the brush size and grid shape.
  • Use Bounding Box option to detect the dimensions of the geometry and place object correctly.
  • Snapping. Quickly place objects to the center of the polygon, faces or vertices.
  • Flexible settings help you cope with various situations: orientation inversion, selected polygons, etc.
Version 1.1 Changes
  • NEW: Cinema 4D R19 compatibility.
  • NEW: Automatic axis direction detection based on polygon normal and camera position.
  • NEW: Auto orientation (+Y,-Y,-Z). Target 4D detects surface normal angle and automatically choose relevant orientation. Best for using to place objects on vertical and horizontal surfaces like a floor, walls and ceiling.
  • NEW: New Quick Options Menu on pressing Escape button. Easy to selecting between active objects and placing modes. No need to back to main options window for quickly changing some parameters.
  • NEW: Referenced Layer option. Now you can apply layer to copies getted from the copied object.
  • Fixed: Crash after using interactive options.
  • Enchanced: Speed improvement of detecting objects Bounding Box.
  • Enchanced: Improvement of detecting Instance object surface.
  • Other bugs fixes and improvements.
  • Fast and easy
    Just click on the surface and the plug-in will move or copy the object to the right place!
  • New awesome tool for your workflow
    Advanced copy capabilities
    Create multiple copies on the surface in a few clicks!
    Copy by the grid with random transformation
    Copy by line
    How to install plugin
    Unpack archive with installation files to here:
    c:\Users\%USERNAME%\AppData\Roaming\MAXON\CINEMA 4D (version whatever)\plugins\
    If you are on a Mac just go to Applications > Maxon > Cinema 4D (version whatever) > plugins\
    Restart Cinema 4D.
签名被屏蔽
凌晨6点科韵路  发表于 2022-6-28 14:51:03
没有购买~没有提取码
