尊敬的 游客,如果您要查看本帖关注 或 回复可见内容请 关注或 回复后刷新页面查看!
Retopology is a slow process, so lets not do it more than once! SoftWrap can reutilize previous models as topology for your new models!
What is this add-on for? It's meant for retopology but works differently than most retopo add-ons. Softwrap just reutilizes the topology from similar models which is faster than doing it from scratch. If you are in need of a human basemesh, you can get a free one which I made, even if you don't purchase this product. How does it work? - Softwrap works by running a custom softbody simulation while snapping in a way similar to the shrinkwrap modifier. Thus, the name.
It was created by accident during some random experiments with particle simulations that also led to the creation of Tessleator but has evolved quite a bit since. Tutorials: - The best way to learn how to use softwrap is by trying it.
It has a few sliders that are hard to explain, luckily, they are easy to "get" once you play with them.
Its softbody simulation engine is non-physically-based and was specifically built for the purpose of retopology and contains custom dynamics that aim at giving the user control to freely manipulate the mesh while it automatically snaps onto a sculpture\scan.
重新拓扑是一个缓慢的过程,所以不要重复进行!SoftWrap 可以重新利用以前的模型作为新模型的拓扑! 这个插件有什么用? 它适用于重新拓扑,但与大多数重新拓扑附加组件的工作方式不同。 Softwrap 只是重新利用类似模型的拓扑结构,这比从头开始更快。 如果你需要一个人类basemesh, 你可以免费得到一个我制作的, 即使你不购买这个产品。 它是如何工作的? - 软包裹通过运行自定义软体模拟同时以类似于收缩包裹修改器的方式进行捕捉来工作。
