QuickAssembly 2022 快速组装自动散射Quick Assembly
65 2
发布于 2023-6-24 14:19:01
插件类型: Blender
版本信息: 2022
软件版本要求: 3.1.2
官网地址: https://jamajurabaev.gumroad.com/l/bnmmq
QuickAssembly 2022 for Blender 3.1.2
Hey guys Jama and I are back with another addon for Blender called QuickAssembly! We wanted to create a tool that can automate working with Geometry Nodes and Instances so that artists can simply click a button and have entire procedural setups built for them with maximum performance. With this tool you can array, scatter, add a variety of fx such as ivy/snow/damage and procedurally assemble your scene.
Array
Linear Array
- Simple Linear Array using instances for maximum efficiency
Radial Array
- Radial Array with a variety of settings using instances for maximum efficiency
Brick Array
- Linear Array with offset setting to create bricks/tiles
Curve Array
- Array objects onto a Curve
Curve Array Collection
- Array will be comprised of objects in the active collection allowing for a fully procedural workflow (change the objects in the collection at any time and it will update)
Scatter
Object Scatter
- Scatter selected objects onto the active object
Object Scatter Collection
- Scatter will be comprised of objects in the active collection allowing for a fully procedural workflow (change the objects in the collection at any time and it will update)
Texture Scatter
- Scatter selected objects onto the active object based on a texture
Texture Scatter Collection
Volume Scatter
- Scatter selected objects inside the volume of the active object
Volume Scatter Collection
Effects
Shrinkwrap
- Shrinkwrap the selected mesh onto the active object
Cloner
- Duplicate the selected object as many times as you want and randomize all of the copies transformations
Randomizer
- Randomize the transformation of all your selected objects
Randomizer Collection
- Randomize the transformations of all objects in the active collection allowing for a fully procedural workflow (change the objects in the collection at any time and it will update)
Growth
- Grow Ivy or any selected geometry onto the active object
Growth Collection
- Grow Ivy or any selected geometry onto all the objects in the active collection allowing for a fully procedural workflow (change the objects in the collection at any time and it will update)
Snow
- Create Snow on top of your selected objects
Snow Collection
- Create Snow on top of all the objects in the active collection allowing for a fully procedural workflow (change the objects in the collection at any time and it will update)
Damage
- Add some damage to the selected objects
Exploder
- Explode your selected objects into voronoi chunks
Spikes
- Scatter Icycles or any type of spiky geometry onto your selected objects
Proxy
- Create an instanced proxy of your selected objects
Displace
Texture Displacement
- Displace your mesh with a triplanar texture
Noise Displacement
- Displace your mesh with a simple built in Noise texture
Apply Assembly
- Apply Assembly will finalize your assembly and turn it into real geometry
参与人数 3元素币 +43 活跃度 +13 展开 理由
xiaohei + 12 + 4 这就是大佬的世界嘛
kiwi + 17 + 4 压箱底的宝贝吧这是
神座 + 14 + 5 楼主是好人
收模型,杂志,教程,插图,插件,软件,拿来卖。
逆水寒  发表于 2022-5-22 21:57:44
不错
元素界王神  发表于 2022-12-31 17:54:24
强大啊!
