Blender HDRI环境制作模拟插件 HDRi Maker 2.0.87 For Blender 3.0+
237 7
发布于 2024-5-18 14:48:51
插件类型: Blender
版本信息: 2.0.87
软件版本要求: Blender 3.0+
官网地址: https://blendermarket.com/products/hdri-maker
Expires=1653200214Signature=BZupdr9Go0H8JRCYTGHcJ2WNPDr581jtoQgFbuInxtcBZ1edOkxzRjwbTYJLMGG0ILtrgUM-32EthSgCoGEyBvAIZvjnwy44VlYaemcN64354u8ao2DHokMP5LyimgAvKCxkCfUxZ4p0g9931Aybxv90MFT0covTLeKiI~QTw-qCw6ba7urc3.jpg
HDRi Maker is a powerful add-on created to be simple and fast
Keyword = Speed!   Almost 400 included ready to useSee what you can do:
All the backgrounds you see are included in the addon!
uploads/1589132683991-Robot_01.gif
Finally full immersion in an HDRi environment
With 1 click, you can create animated fog
You can add the backgound material to any object
in this example I use an object created with "A.N.T.Landscape" already present in the addons of your Blender
Now it's easy to create videos inside your dome
This example was rendered in Eevee, about 1 second per frame with an 8k background on a GTX1080TI.
More freedom of video with the camera:
Note: Not all backgrounds will be perfect for this type of animation (Although all image based backgrounds can be used for this purpose)
All backgrounds with open panoramas are very good for this purpose
Have you ever thought of animating a vehicle inside an HDRI without inserting any other 3D model? Now it's simple:
This background is already included in HDRi Maker
Do you want to dig into the projected ground? No problem:
The new wrap button is designed to interact with the terrain (Water from Extreme PBR addon)
Trick the eye !, This is only a car that travels on an HDRI "Photography", the road you see is not infinite, but the trick is now easy:
We have also revolutionized the shadow catcher system from the previous version, see for yourself the results of this work:
Shadow catcher with adjustable reflections, always available with any background (Also in all those you will create yourself)
works on Blender 2.79 and 2.8x, it solves the problem of the shadow catcher on ground not present in EEVEE.
You can control the colorization and the background blur:
Alpha ready:
directly in Eevee, but also in Cycles render:
We moved the controls directly into the panel, to easily switch to the transparent background:
Displacement catcher:
You can adjust the "Hardness" of the displacement, it's all automated:
Water catcher:
Now there is also an option for animated water on the shadow catcher plan, it is simple and ready to use:
Save your background directly from the model, it only takes 2 clicks:
Now you can easily create a 360 degree background directly from your 3D model. This has now become a very easy operation:
Almost 400 HDR ready to use in 1/2/4/8k:
You can redesign the previews of your backgrounds saved in the "User category" section to improve your preview:
Very useful for creating realistic backgrounds for your models, with ultra realistic lighting, Here are some examples:
No light in the scene, just background and model with the blender 2.8x+ cycles engine
Tiger model by Quentin Le Duff on thislink. License  CC BY 4.0
This model is rendered with eevee and with a bit of Bloom:
Even on interiors the light source is very realistic, in this example the lights in the scene are off, the only light source passes through the windows:
Archviz Interior Scene For Eevee & Cycles [Archviz 2.8 - Scene01] created by BD3D  Rendered in Cycles: sample 1024 + Denoise in Blender 2.8  1280x720
The hdr lighting really makes the difference:
All the backgrounds are in 1K 2k 4k 8k
New interface:
This interface is designed to be simple and intuitive, we have changed the preview system, now they are very large and allow a good preview that immediately gives the idea of what background you are going to choose
23 categories for almost 400 backgrounds from hdrihaven, all carefully categorized:
Realtime with shadow catcher emulation in Blender 2.8x EEVEE engine:
Smart Management system:
If you are looking for a tool to create 360 background, without having to do anything but installing it, this is what you are looking for.
See how an engineering scene can be quickly enriched:
It's all ready to use just install it.
Almost 400 Backgrounds at 360° Ready to use, under cc0 License
Packed all together to be ready for use, we don't want professionals to waste time, just install it through the installation guide inside.
Follow my youtube channel You’ll find tutorials that illustrate the add-on
See how the HDRi Projected works:https://youtu.be/uvVD9Zuo06c
Playing with HDRi Maker 2.0:https://youtu.be/ziWM0CljpeI
Do you want to expand your HDRi Maker library? Here you can find 90+ additional backgrounds in EXR format (Compatible with HDRi Maker).
Remember to give credit to the author if you use them for your works:
收模型,杂志,教程,插图,插件,软件,拿来卖。
元素界王神  发表于 2022-5-22 21:10:33
还能这么玩,我也是第一次知道啊!
Teny  发表于 2022-5-22 21:25:46
谢谢楼主分享!!!
棋子  发表于 2022-5-27 09:16:45
感觉很不错啊!!
爱桑  发表于 2022-7-27 14:42:46
KaikoWoo  发表于 2023-4-12 21:41:58
尊敬的KaikoWoo,如果您要查看本帖关注 或 回复可见内容请关注或回复后刷新页面查看!
梦骑士  发表于 2024-5-22 18:43:28
6666
xufengsss  发表于 2024-7-17 11:59:09
太好, 找了好久
