【搬运】【ZBrush插件】Zplugin: ZAdjustor v2.1
ZAdjustorZplugin插件效率神奇工具 14901 4
发布于 2023-11-4 18:34:55
软件类型: 三维·建模 平面·绘画 插件 其它软件或系列集合
版本信息: v2.1
系统要求: -
官网地址: http://archive.zbrushcentral.com/showthread.php?182163
原文地址:http://archive.zbrushcentral.com/showthread.php?182163
ZAdjustor插件:只需在 X 和 Y 轴上移动鼠标/触控笔,同时按住热键,即可调整绘图大小、焦点偏移(和 Z/RGB 强度)。调整画笔大小或焦点偏移时不要再打断您的工作流程,而是通过视觉反馈平滑地调整它,就像在 mudbox、photoshop 等中一样......!!!
ZBrush has got a wonderful seamless smooth workflow, and to me adjusting draw size or focal shift with a slider is quite annoying. I wanted to have a tool which would do it more naturally, without having to relate to precise numbers, just like like in Photoshop with Alt or Maya/Mudbox holding B key. The adjust plugin shipped with zBrush did not do it for me, so I started to write my own one, and there it is.
So : You choose between one of the six independent profiles with the top buttons, set whatever parameters you like, assign a hotkey to the big button at the bottom, then while sculpting you hold that hotkey down and adjust a chosen parameter with X axis and another one with Y. While doing so the cursor stays in place. While doing this, you have instant smooth visual "analog" feedback of brush size and focal shift, as well as numerical in the status bar if you enable the Display option. You can also adjust Z Intensity and RGB Intensity if you want.
You have six independent profiles, each with its own settings and hotkeyable action button, so you can have up to six different hotkeys adjusting various parameters in various ways.
Axis culling means that just after starting to hold the hotkey, if you aim within a certain Angle from the horizontal/vertical axis, the other axis will be filtered out so you won't have to be extra-precise to avoid changing its value. If you aim outside the defined Angle then you will adjust both axis just like usual or if you set angle on 45° then there will always be an axis culled. The Length slider sets the number of pixels traveled that the plugin will take in account when it evaluates axis culling. Lower it for optimal response, raise it if you find the test too much precise. (For example, with the settings shown in the image, if just after starting to hold the hotkey you go straight to the right/left, you'll only adjust Brush Size, if you go straight up/down you'll only adjust Focal Shift, and if you go diagonally (so 45° - or within 10° from 45° as Angle is set to 35) you'll adjust both at the same time.)
To adjust values for mask/smooth/clip brush, you have to first hold the hotkey, then without releasing it, press and hold the modifier one (SHIFT/CTRL). You have to do it in that order. So, choose your hotkeys wisely : it is best to choose a single key which also is not part of another zBrush shortcut with CTRL/SHIFT added. So, for example : D key first seems to be a nice choice, till you remember CTRL-D is for subdividing ! You won't be able to adjust mask brush settings. Two solutions : you can remove all conflicting shortcuts, or choose another key.
The current version is zAdjustor v2.0, now available on both windows and mac osx. There is a separate package for windows and osx, download the right one for your OS below.
Voilà ! Hope you will like it, use it and find it useful. I would like a lot of feedback (I hope less problem reports and more bugless thanks , but both are really needed), so don't hesitate.
Also pardon me for my not so good English and if you see any mistake let me know.
Happy sculpting everyone !!!
> Important note :
When answering to support questions here on ZBrushCentral or other forums, I noticed that, whereas most people seems to get how to make the plugin work almost instantly, almost everyone that was having difficulties had them only because of comprehension issues.
So, please pay attention to this chapter :
- This plugin is made for tablets just as much as regular mouses. It is working with either, and is as useful while holding a stylus as it is while working with a regular mouse.
- Please, be very attentive to the installation process !!! About 50% of the asked questions about this plugin are from people that didn't extract the archive in the right folder. The other 50% were from people that did not understand properly the way the plugin operates or that didn't know how to define a hotkey in ZBrush :
- You must NOT click on the big button at the bottom to use it. This button's only purpose is to allow the user to set up a hotkey that will be the plugin's trigger. You set up the hotkey like usual in ZBrush : CTRL+ALT+CLICK on the button, then ZBrush asks to press a key on the keyboard. Then, to use the plugin, while working over the canvas, HOLD that hotkey down, then move your mouse or stylus to change the values. Then, when you are done changing the values, just release the hotkey.
- You have 6 different profiles that you can select with the numbers at the top of the plugin's palette, and they have all their own 'Big button' to set up a hotkey for each. Use as many as you want.
- Settings are automatically saved. They are not stored with ZBrush own preferences but instead in some files created in the plugin's folder. So you don't have to press 'Store config', ZAdjustor's settings are always saved each time you edit them.
- You must not click with the mouse/stylus while using the plugin. It won't crash or do anything bad, but won't do anything good either. It just isn't the way the plugin is used.
- The page you are on is the official ZAdjustor's thread. Don't hesitate to tell what you think about the plugin, ask a question or for support, say thanks if you like it, just confirm if it's working...
ZBrush 有一个很棒的无缝流畅的工作流程,对我来说,用滑块调整绘图大小或焦点偏移是很烦人的。我想有一个工具可以更自然地完成它,而不必涉及精确的数字,就像在 Photoshop 中使用 Alt 或 Maya/Mudbox 按住 B 键一样。zBrush 附带的调整插件不适合我,所以我开始编写自己的插件,它就在那里。
所以:您可以使用顶部按钮在六个独立配置文件中选择一个,设置您喜欢的任何参数,为底部的大按钮分配一个热键,然后在雕刻时按住该热键并使用 X 轴调整所选参数,然后另一个带有 Y。这样做时,光标保持在原位。执行此操作时,如果启用“显示”选项,您将立即获得画笔大小和焦点偏移的平滑视觉“模拟”反馈,以及状态栏中的数字。如果需要,您还可以调整Z 强度和RGB 强度。
您有六个独立的配置文件,每个配置文件都有自己的设置和热键操作按钮,因此您最多可以有六个不同的热键以各种方式调整各种参数。
轴剔除意味着刚开始按住热键后,如果您在水平/垂直轴的某个角度范围内瞄准,另一个轴将被过滤掉,因此您不必过于精确以避免更改其值。如果您瞄准定义的角度之外,那么您将像往常一样调整两个轴,或者如果您将角度设置为 45°,那么总会有一个轴被剔除。长度_滑块设置插件在评估轴剔除时将考虑的行进像素数。降低它以获得最佳响应,如果您发现测试过于精确,请提高它。(例如,如图所示的设置,如果刚开始按住热键后直接向右/向左移动,则只会调整画笔大小,如果直接向上/向下移动,则只会调整焦点移位,如果您沿对角线移动(因此 45° - 或在 45° 的 10° 范围内,因为角度设置为 35),您将同时调整两者。)
要调整蒙版/平滑/剪辑画笔的值,您有首先_按住热键,然后不松开它,按住修饰符一(SHIFT/CTRL)。你必须按这个顺序去做。所以,明智地选择你的热键:最好选择一个不属于另一个 zBrush 快捷键的单个键,并添加了 CTRL/SHIFT。因此,例如: D 键首先似乎是一个不错的选择,直到您记得 CTRL-D 用于细分!您将无法调整蒙版画笔设置。两种解决方案:您可以删除所有冲突的快捷键,或者选择另一个键。
当前版本是 zAdjustor v2.0,现在可在 windows 和 mac osx 上使用。windows 和 osx 有一个单独的软件包,请在下面为您的操作系统下载正确的软件包。
瞧!希望你会喜欢它,使用它并发现它有用。我想要很多反馈(我希望更少的问题报告和更多的错误感谢,但两者都是真的需要),所以不要犹豫。
也请原谅我的英语不太好,如果您发现任何错误,请告诉我。
祝大家雕刻愉快!!!
>重要提示:
在 ZBrushCentral 或其他论坛上回答支持问题时,我注意到,虽然大多数人似乎几乎立即知道如何使插件工作,但几乎每个遇到困难的人都只是因为理解问题而遇到问题。
所以,请注意这一章:
-这个插件是为平板电脑制作的,就像普通的鼠标一样。它可以与任何一个一起使用,并且在握住手写笔时与使用普通鼠标时一样有用。
- 请注意安装过程!!!大约 50% 的关于这个插件的问题来自没有在正确文件夹中提取存档的人。其他 50% 来自不正确理解插件操作方式或不知道如何在 ZBrush 中定义热键的人:
-您不能单击底部的大按钮来使用它。这个按钮的唯一目的是允许用户设置一个热键作为插件的触发器. 您像往常一样在 ZBrush 中设置热键:CTRL+ALT+CLICK 按钮,然后 ZBrush 要求按键盘上的一个键。然后,要使用该插件,在画布上工作时,按住该热键,然后移动鼠标或触控笔以更改值。然后,当您完成更改值时,只需释放热键。
- 您有 6 个不同的配置文件,您可以使用插件面板顶部的数字来选择它们,并且它们都有自己的“大按钮”来为每个配置文件设置一个热键。尽可能多地使用。
- 设置会自动保存。它们不与 ZBrush 自己的首选项一起存储,而是存储在插件文件夹中创建的一些文件中。因此,您不必按“存储配置”,每次编辑 ZAdjustor 的设置时都会保存它们。
- 使用插件时不得使用鼠标/触控笔单击。它不会崩溃或做任何坏事,但也不会做任何好事。这不是插件的使用方式。
- 您所在的页面是 ZAdjustor 的官方主题。不要犹豫,说出您对该插件的看法,提出问题或寻求支持,如果您喜欢它,请说谢谢,只需确认它是否有效......
一枝独秀007  发表于 2023-3-14 10:45:30
hao
浅释丶  发表于 2023-4-7 02:15:59
哦哦
qq_Yune_JBh  发表于 2024-6-3 14:04:56
选择性孤独  发表于 2025-7-7 19:56:14
asdadasdad
