3DS MAX展UV贴图插件 Unwrap Pro v1.0.4 For 3DS MAX 9 – 2022 + 使用教程
208 2
发布于 2024-5-3 10:36:50
价格:6元素币(或1余额) 百度网盘 销售总额:18元素币 购买人数:3
尊敬的游客 ,本内容需要支付 6元素币十分之一的[余额] 来购买.
可以在3DS MAX中更精确的进行贴图展UV,减少叠加等Unwrap Pro is a 3ds Max plugin which unwraps meshes while producing low distortion, overlap free, weighted density UVs unlike the 3ds Max Peel command which produces overlapping UVs with high area distortion.It is very fast (a 1 million triangle mesh was unwrapped in 23 seconds). It is easy to use (just select some UVs and hold down a button).Unwrap Pro will not add seams or pack UVs for you.支持的版本:
  • 3DS MAX 2009/2010/2011/2012/2013/2014/2015/2016/2017/2018/2019/2020
安装步骤:
  • 关闭3DS MAX
  • 如果是2014或者低版本,安装下Microsoft Visual C++ 2010 Redistributable x64.exe
    如果是2015或者低版本,安装下Microsoft Visual C++ 2015 Redistributable x64.exe
  • 拷贝对应版本plugins里面的Unwrap Pro.dlm和libiomp5md.dll到C:\Program Files\Autodesk\3ds Max xxxx
  • 打开3DS MAX,在修改器找到Unwrap Pro即可
shareかtwo  发表于 2023-5-29 15:38:18
里面没有安装文件
